Home > Technical (L322) > L322 4.4 TDV8 putting out clouds of white smoke at idle. |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2488 |
I doubt that a fault would be detected and if the timing was retarded then I would expect idling to be very smooth.
27th Oct 2024 1:56am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3249 |
The exhaust gas temp is still high enough even on cold start to vaporise excess oil or diesel in the exhaust. White smoke on startup is a classic sign of exhaust side turbo seal failure and it would still run smoothly. 2012 TDV8 Vogue (L322) |
27th Oct 2024 7:52am |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3106 |
I had a look under the bonnet of our 4.4 as I was in the workshop next to it earlier.
27th Oct 2024 6:49pm |
RobErica Member Since: 16 Nov 2023 Location: Loosbroek Posts: 38 |
That white smoke kan be caused by the turbo leaking on the exhaust side. It then just heats the oil instead of burning it. Uou wont find much oil in the intercooler.
27th Oct 2024 7:45pm |
Dijit Member Since: 09 Jul 2012 Location: Glasgow Posts: 161 |
I accept what you say but not in the first two seconds of starting from stone cold surely? The video last 23 seconds. Granted I revved it when the smoke became a white out but at idle within 2 seconds or less of starting? Sorry I can't see that. Rehab is for quitters!!! RR 2007 3.6 TDV8 Java Black * RR 2007 3.6 TDV8 Zermatt silver * RR 2000 P38 4.6 Met red * Mercedes 300TE 4-Matic * Jaguar 420 (1969) * Nissan 300Z Citroen XM 2.5TD X 6 Bentley Continental R Hydrocon Highlander Hydrocon Hamilton Hydrocon Huntly Am told the ones with a * are to be offered for sale! 😳 Departed LR 1992 110 2.5TD RR 2000 Holland & Holland 4.6 LPG RR 4.2 Supercharged with LPG, Vogue SE 2007 Buckingham Blue RR 2002 4.4 V8 Zambesi Silver |
27th Oct 2024 8:10pm |
I think a leaking exhaust side turbo oil seal will smoke almost immediately on cold start. As long as there are hot combustion gasses entering the turbo exhaust side and there is oil in there it will vaporise. 2012 TDV8 Vogue (L322) |
27th Oct 2024 9:17pm |
It’s not blue smoke so you can effectively rule out an intake oil problem. Turbo’s can leak from the compressor side but usually it’s the exhaust side as this is where the combination of heat and oil lubrication problems will do the most damage. 2012 TDV8 Vogue (L322) |
27th Oct 2024 9:24pm |
JayGee How can you test for that? |
27th Oct 2024 9:48pm |
JayGee How can you test for that? Rehab is for quitters!!! RR 2007 3.6 TDV8 Java Black * RR 2007 3.6 TDV8 Zermatt silver * RR 2000 P38 4.6 Met red * Mercedes 300TE 4-Matic * Jaguar 420 (1969) * Nissan 300Z Citroen XM 2.5TD X 6 Bentley Continental R Hydrocon Highlander Hydrocon Hamilton Hydrocon Huntly Am told the ones with a * are to be offered for sale! 😳 Departed LR 1992 110 2.5TD RR 2000 Holland & Holland 4.6 LPG RR 4.2 Supercharged with LPG, Vogue SE 2007 Buckingham Blue RR 2002 4.4 V8 Zambesi Silver |
27th Oct 2024 9:49pm |
Test for a leaking exhaust side turbo oil seal? 2012 TDV8 Vogue (L322) |
27th Oct 2024 9:54pm |
JayGee Yes, test for a leaking turbo oil seal. Rehab is for quitters!!!
27th Oct 2024 10:33pm |
White smoke that smells of engine oil is the obvious one. Collect enough of it in a rag over the tailpipe and it should be easy to tell if it’s oil or diesel. Unbolt the down pipe from the turbo and an oil leak will be obvious as will any excessive turbo shaft play. Main reason for turbo oil seal fail is oil starvation. 2012 TDV8 Vogue (L322) |
27th Oct 2024 10:42pm |
Thanks JayGee. Anything else that can be checked? Rehab is for quitters!!!
27th Oct 2024 10:51pm |
Actualy you may not even have to unbolt the downpipe as if it's leaking oil it will likley be seeping out of the joint between turbo and downpipe. 2012 TDV8 Vogue (L322) |
28th Oct 2024 7:18am |
