![]() | Home > Technical (L322) > L322 4.4 TDV8 putting out clouds of white smoke at idle. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7894 ![]() ![]() ![]() |
Make sure the oil filter hasn’t been fastened down that tight that the seal below it has gone flat instead of round. Some garages do this to try and solve the oil leak, but obviously makes things worse.
Dijit Member Since: 09 Jul 2012 Location: Glasgow Posts: 165 ![]() ![]() ![]() |
Update 4.
Rackers Member Since: 04 Apr 2022 Location: Portsmouth Posts: 80 ![]() ![]() ![]() |
I don't know if it's the same with diesels but my IID was able to show injector pulse widths on my 5.0 which can pinpoint a problem one! |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3179 ![]() ![]() ![]() |
On the 4.4 there’s no option in the IID Tool or SDD to monitor anything to do with the injectors unfortunately. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2639 ![]() ![]() |
Could be more than 1 faulty injector, especially if the system has had a dose of petrol.
Curiosity got the better of me so I had a look in the workshop manual for the 4.4 Diesel... I also did a bit of Googling...
Can injector offset learning be forced? That should show-up any injector that's out of spec. |
Re: Update 4
If it ain't broke....... ![]() RR 2007 3.6 TDV8 Java Black * RR 2007 3.6 TDV8 Zermatt silver * RR 2000 P38 4.6 Met red * Mercedes 300TE 4-Matic * Jaguar 420 (1969) * Nissan 300Z Citroen XM 2.5TD X 6 Bentley Continental R Hydrocon Highlander Hydrocon Hamilton Hydrocon Huntly Am told the ones with a * are to be offered for sale! 😳 Departed LR 1992 110 2.5TD RR 2000 Holland & Holland 4.6 LPG RR 4.2 Supercharged with LPG, Vogue SE 2007 Buckingham Blue RR 2002 4.4 V8 Zambesi Silver |
That is what I think in light of the HP fuel rail immediately losing pressure when the engine is turned off but interestingly it idles smooth as silk. Rehab is for quitters!!! RR 2007 3.6 TDV8 Java Black * RR 2007 3.6 TDV8 Zermatt silver * RR 2000 P38 4.6 Met red * Mercedes 300TE 4-Matic * Jaguar 420 (1969) * Nissan 300Z Citroen XM 2.5TD X 6 Bentley Continental R Hydrocon Highlander Hydrocon Hamilton Hydrocon Huntly Am told the ones with a * are to be offered for sale! 😳 Departed LR 1992 110 2.5TD RR 2000 Holland & Holland 4.6 LPG RR 4.2 Supercharged with LPG, Vogue SE 2007 Buckingham Blue RR 2002 4.4 V8 Zambesi Silver |
Are you sure that it isn't oil smoke, possibly from the intercooler. I would remove the outlet hose from the intercooler to see how much oil comes out.
Oil in the IC would get burnt in the cylinders and create blue smoke. White smoke is oil or diesel vapour and which one it is can easily be identified by the smell. 2012 TDV8 Vogue (L322) |
Thanks for this GraemeS. I'm assuming by PCV you mean the pressure control valve rather than positive crankcase ventilation? The joy of acronyms. If the pressure control valve was dumping the fuel rail pressure that doesn't account for the smoke. Do we know that faulty injector(s) throw up fault codes? Running the fuel rail pressure at idle was circa 350 bar. The minute the engine was switched off it dropped to circa 10 bar. By comparison, the other car, the one I prepared earlier, also idled around 350 bar but when the engine was turned off it held slightly north of 300 bar. Turning to
Even if the intercooler was full of oil, remember the smoke starts within 1-2 seconds of the engine firing from stone cold. Even if the exhaust was full of oil it couldn't heat up quickly enough to create the white smoke. The exhaust tailpipes are slightly sooty but not abnormally so IMHO. However there is definitely a strong smell of what I think is diesel. So let's explore that it's not injectors given how smoothly it runs and let's say the pressure control valve is gubbed allowing the fuel rail pressure to drop, what else could cause the instant white smoke? Water in the fuel is a possibility. Petrol in the tank? Not sure and the range was showing 0 miles. I've now added about 4 gallons (of diesel not petrol ![]() Air leak somewhere? Would that obliterate whole cities instantly? Remember this smoke was instantaneous at idle and idle was smooth so I'm assuming the main turbo is contributing very little and the secondary should be stationary. Also it's not throwing up any fault codes. Do these random jottings make any sense or trigger any other thoughts? Hands up, I come from L322 3.6 TDV8s so the 4.4 TDV8 is all new to me. My instincts are that it's something simple and I'm open to there being possibly two faults rather than one catch all solution. The joys of the eternal optimist! ![]() ![]() Thanks for all the comments to date. I'm considering them all and gauging how they meet the criteria. Rehab is for quitters!!! RR 2007 3.6 TDV8 Java Black * RR 2007 3.6 TDV8 Zermatt silver * RR 2000 P38 4.6 Met red * Mercedes 300TE 4-Matic * Jaguar 420 (1969) * Nissan 300Z Citroen XM 2.5TD X 6 Bentley Continental R Hydrocon Highlander Hydrocon Hamilton Hydrocon Huntly Am told the ones with a * are to be offered for sale! 😳 Departed LR 1992 110 2.5TD RR 2000 Holland & Holland 4.6 LPG RR 4.2 Supercharged with LPG, Vogue SE 2007 Buckingham Blue RR 2002 4.4 V8 Zambesi Silver |
A specific fault code will be set for each injector for which the fueling cannot be adjusted within the allowed range so as to cause the crankshaft to accelerate at the same rate as the other injectors. It's an ongoing adjustment over time which possibly occurs at idle. P02CD/P02CF/P02D1/P02D3/P02D5/P02D7/P02D9/P02DB
