Home > In Car Electronics (L322) > CarPlay for under £100 |
madnessgonemad Member Since: 28 Aug 2020 Location: Kent Posts: 96 |
The best way to remove it is with a plastic trim removal tool. You can get a set cheaply from eBay. If you use a screwdriver you can mark the trim. The vent is attached to the tube bit but that just pulls off once the the vent is released |
14th Oct 2024 11:11am |
Gr4h4m Member Since: 08 Oct 2020 Location: Chester Posts: 83 |
Thanks,
21st Oct 2024 9:56am |
Driyage Member Since: 30 Apr 2024 Location: Essex Posts: 40 |
Yeah the aux is a pain... I've actually ordered some inline Aux amplifier and a voltage regulator and *eventually* planning on modifying the loom so it's all hidden...
21st Oct 2024 10:27am |
Yes, the long aux cable is a pain. But it is easy to hide on its run to the back. It can go behind the trim in the footwell and then you can push it under the tunnel trim. There is a post on here somewhere describing how to hide the aux connection at the back. I must admit I haven’t bothered.
21st Oct 2024 2:48pm |
I’ve taken a few photos copying the OP’s install, but trying to show the over all look.
24th Oct 2024 7:51am |
That looks a good job with your leather finish.
24th Oct 2024 9:25am |
That looks fantastic! I was considering sinking mine in like you did, but it covered a bit too much of the lower screen.
24th Oct 2024 9:34am |
RobsterPC Member Since: 14 Oct 2024 Location: Kent Posts: 53 |
I'm collecting a few bits ready to give this a go. I've got some aluminium plate that I can bend to shape to make it. How deep does the plate have to slide into the dash? Related to this, my plan is to run power from the fuse box to a multi-port USB hub so that I can power the unit and also the MagSafe phone charger I have on the drivers side. Rather than having cables all over the place, how easy is it to get a cable through the dash, exiting either side of the existing screen or in a similar location? This is for a 2012 for reference. |
6th Nov 2024 10:14am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3541 |
does anyone have an up-to-date link to the unit?
6th Nov 2024 2:02pm |
My 10.6" unit from AliExpress, all of £46, just arrived. I'm going to give it a go later, if its something to recommend I'll share the details. |
6th Nov 2024 3:15pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3758 |
They really are a bargain at less than £50., I paid nearly 3 times that nearly 4 years ago, but it has been an investment well worth every penny.
6th Nov 2024 5:18pm |
The units are amazingly cheap now and seem to be very decent quality with a very responsive touch screen. I recently bought a Roadtop to do the installation for a friend at under £50.I paid about £90 a year or so ago!
6th Nov 2024 6:35pm |
Thanks for the replies, I had 2 questions
6th Nov 2024 10:34pm |
