Home > In Car Electronics (L322) > CarPlay for under £100 |
madnessgonemad Member Since: 28 Aug 2020 Location: Kent Posts: 93 |
The best way to remove it is with a plastic trim removal tool. You can get a set cheaply from eBay. If you use a screwdriver you can mark the trim. The vent is attached to the tube bit but that just pulls off once the the vent is released |
14th Oct 2024 12:11pm |
