Home > In Car Electronics (L322) > CarPlay for under £100 |
Driyage Member Since: 30 Apr 2024 Location: Essex Posts: 42 |
Hi,
10th Jul 2024 10:25am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3786 |
You might want to search out a post detailing a very neat modification to the rear aux which allows a lead to be plugged in permanently and the lid to still close.
10th Jul 2024 11:16am |
madnessgonemad Member Since: 28 Aug 2020 Location: Kent Posts: 104 |
Not much trim needs to be removed. You can feed the power cable ( and the aux) under the dashboard and pick it up in the front corner.
10th Jul 2024 11:22am |
I’ll keep searching, but basically you just need a 3.5mm aux extension lead with a 90’ plug on the end that plugs into the socket., meaning no modification to the existing car wiring.
10th Jul 2024 11:48am |
RINOR Member Since: 10 Oct 2021 Location: VIKEN Posts: 7 |
Could you please post a new link to this unit? Tried it, but comes up with “unavailable”. Thanks😊 |
11th Jul 2024 3:50am |
The exact one that I got is not around now.
12th Jul 2024 9:03am |
Thanks Baltic Blue. I actually already do this. I was thinking of a wiring mod to completely hide the aux cable in the armrest somewhere. Yes, I know I’m ocd…………….. |
12th Jul 2024 9:06am |
Ok took the plunge today and removed the centre vent, and ran the wires down to the fuse box.
13th Jul 2024 2:25pm |
Ok I think I found Aux input mod:
13th Jul 2024 3:09pm |
I know that I have read a post detailing a very simple mod to the rear aux socket, but have not managed to find it using search.
13th Jul 2024 4:10pm |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 689 |
With regard to modifying the rear auxiliary socket (2006-2012 L322s) what I've done in all of mine is remove the plastic cover below the flap which conceals the auxiliary port and power point.
14th Jul 2024 8:44am |
So with thanks to madnessgonemad I’ve finally done mine:
20th Aug 2024 8:10am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35459 |
theres a much easier mounting solution discussed in this thread,
20th Aug 2024 8:39am |
That’s a neat solution, thanks! I’ll look through the thread to figure out the wiring for that |
20th Aug 2024 8:43am |
