Home > In Car Electronics (L322) > CarPlay for under £100
Page 4 of 5 <12345>
Gr4h4m
United Kingdom 2010 Range Rover Vogue SE 4.4 V8 Santorini Black
Hi all, does the central tops dash vent just pop out? Is there any special technique it remove it? I have just got my hands on some of these screens and want to mimic the install.
Thanks for any help.
Post #702144 14th Oct 2024 10:20am
madnessgonemad
The best way to remove it is with a plastic trim removal tool. You can get a set cheaply from eBay. If you use a screwdriver you can mark the trim. The vent is attached to the tube bit but that just pulls off once the the vent is released
Post #702148 14th Oct 2024 12:11pm
Gr4h4m
Thanks,
I have been working on this this weekend. Making the cover plate takes some time, I covered with some leather in the end to make it look as neat as possible.
The aux cable is a pain… I didn’t realise it was in the back panel… I have ordered longer cable from Amazon and will run that I the future.
I think dropping it in to the vent area make it look very factory, I would like to neaten the front edge up but you can’t have everything for just over £50.
Post #702753 21st Oct 2024 10:56am
Driyage
Yeah the aux is a pain... I've actually ordered some inline Aux amplifier and a voltage regulator and *eventually* planning on modifying the loom so it's all hidden...
So far it's holding up and working well.
Post up some pics please !! Very Happy
Post #702754 21st Oct 2024 11:27am
madnessgonemad
Yes, the long aux cable is a pain. But it is easy to hide on its run to the back. It can go behind the trim in the footwell and then you can push it under the tunnel trim. There is a post on here somewhere describing how to hide the aux connection at the back. I must admit I haven’t bothered.
My plastic panel matches the top of the dash very well ( by sheer fluke) but I would be interested in seeing your leather job.
Picture please!
Post #702770 21st Oct 2024 3:48pm
Gr4h4m
I’ve taken a few photos copying the OP’s install, but trying to show the over all look.
Is wired into the fuse box using a mini fuse piggy back adaptor on the cig lighter fuse, so it turns on as soon as you open the car and off when you hit the lock button, or it times out with overall power shutting down on the car if you don’t lock the doors.
Its stuck to the plastic structure using the original bracket and I made a covering plate out of an old license plate, I did paint it but never likes the look so I covered it with some material I had lying around, it doesn’t match the grain of the dash but it looks neat enough.
What I have found, the wired aux connection works but the amp in the decide is too quiet if you like loud music, the over all quality of the sound is not as good as the Bluetooth straight into the iPod connector in the centre box. Strangely the fm transmitter is louder.
Over all it works and looks ok for £50 the panel takes some time to make with a coping saw… I’ve tried to show the overall install of the panel which just sits there as the knob of the mounting screw puts it under a little tension.
Post #702965 24th Oct 2024 8:51am
madnessgonemad
That looks a good job with your leather finish.
It’s strange that your aux volume is down. I certainly haven’t noticed that and I like to turn up my Dadrock tunes when I’m on my own in the car! Makes me wonder if there is a setting somewhere for aux volume. In my wife’s old Freelander the aux volume was poor until one day I stumbled on a setting for aux vol in the car’s menu. Might be worth investigating.
Good luck with it.
Post #702977 24th Oct 2024 10:25am
Driyage
That looks fantastic! I was considering sinking mine in like you did, but it covered a bit too much of the lower screen.
I managed to source the leather from eBay and it is quite a good match
Post #702978 24th Oct 2024 10:34am
RobsterPC
stan wrote:
theres a much easier mounting solution discussed in this thread,
https://www.fullfatrr.com/forum/topic61372.html
I'm collecting a few bits ready to give this a go. I've got some aluminium plate that I can bend to shape to make it. How deep does the plate have to slide into the dash?
Related to this, my plan is to run power from the fuse box to a multi-port USB hub so that I can power the unit and also the MagSafe phone charger I have on the drivers side. Rather than having cables all over the place, how easy is it to get a cable through the dash, exiting either side of the existing screen or in a similar location? This is for a 2012 for reference.
Post #703870 6th Nov 2024 11:14am
GGDR
does anyone have an up-to-date link to the unit?
. Cheers, Greg
Post #703887 6th Nov 2024 3:02pm
RobsterPC
My 10.6" unit from AliExpress, all of £46, just arrived. I'm going to give it a go later, if its something to recommend I'll share the details.
Post #703888 6th Nov 2024 4:15pm
Baltic Blue
They really are a bargain at less than £50., I paid nearly 3 times that nearly 4 years ago, but it has been an investment well worth every penny.
I bought it because I had moved into an area completely new to me and was struggling to find places, but it solved the problem overnight.
Post #703899 6th Nov 2024 6:18pm
madnessgonemad
The units are amazingly cheap now and seem to be very decent quality with a very responsive touch screen. I recently bought a Roadtop to do the installation for a friend at under £50.I paid about £90 a year or so ago!
Re; the query about routing the cable; it’s easy. Pass the cable under the dash to the corner of the dash with a routing device. I used a straightened out coat hanger.
I don’t quite know what you mean about a metal plate in the recess so can’t comment on that.
Post #703908 6th Nov 2024 7:35pm
RobsterPC
Thanks for the replies, I had 2 questions
1 - How to get the cable through the dash from the glovebox, exiting to the right of the existing screen.
2 - the metal mount I the picture I included, how far does that push into the gap between the top of the dash and the screen? I assume it's just friction from wedging it in that keeps it in place..
Using the unit today, initial observations are that the audio is either phone to the unit then Aux cable into the car or phone to car via Invery or similar. I've got an Invery unit and this keeps the steering wheel controls too so I'll go down that route. It also means there's 1 less cable to route around the car. Secondly, the mount from the screen to the unit outs it too far away from the drivers seat to be comfortable. Getting the unit closer to the driver will be.easier and safer to use. The downside is I lose the inbuilt camera but it came with a remote camera so I can route that if needed.
Tomorrow's job is now to play around with a mount and get some cables routed to neaten things up.
Post #703929 6th Nov 2024 11:34pm
RobsterPC
My mount
1.5mm aluminium plate from Amazon, bent into shape. Velcro to join the screen to the mount. Cost less than £10.
Post #705230 23rd Nov 2024 3:00pm
Page 4 of 5 <12345>
