Home > My Range Rover > 5 RRs and I have to give up
Page 3 of 3 <123
Epson Green
I think the rear subframe bushes have as much influence on the ride quality as the shock absorbers and air bags. Worth replacing if not done already. Kevin
2012 L322 Westminster 4.4 TDV8
1999 P38A 4.0 SE - Sold
Post #701399 3rd Oct 2024 6:41pm
MarianaWestminster
I've heard about that Epsom, another thing to check out.
I've been thinking out the box today about all of this.
What if the steering and engine response/feel are connected.
I'm sure I've read somewhere that the tcm prevents gearshifts etc when it detects the vehicle is turning.
What if the heavy steering is the route cause on all these cars of mine and the laggy engine is a side effect of this?
It could be that with the steering not operating correctly the rest of the car is confused on what it should be doing too?
Post #701478 4th Oct 2024 2:49pm
RRfranz
Austria 2011 Range Rover Vogue TDV8 Santorini Black
The ride quality also improved enormously on my L322 4.4TDV8 after replacing the subframe bushings.
Post #701483 4th Oct 2024 3:09pm
MarianaWestminster
I've heard that too Franz, there was nothing mentioned on the MOT but I will get under there and check them at least visually as soon as I can get back to the car/find time.
I think I should focus on steering for the moment and hope my hunch mentioned earlier regards it effecting the engine is correct.
Post #701582 5th Oct 2024 10:18pm
RRfranz
weniger Vorspur an der Vorderachse macht die Lenkung auch leichter.
Jede Spurstange mit Farbe markieren und um 1/6 Umdrehung länger machen.
1/6 Umdrehung ist circa 0 Grad 5 Minuten Spuränderung.
Auf die Farbmarkierung kann man immer zurückdrehen.
Post #701588 6th Oct 2024 6:33am
RRfranz
Sorry!
Less toe-in on the front axle also makes steering easier.
Mark each tie rod with paint and make it 1/6 turn longer.
1/6 turn is approximately 0 degrees 5 minutes track change.
You can always turn back to the color marking.
Post #701589 6th Oct 2024 6:35am
JayGee
Less toe would also make it less directionaly stable which even at the correct settings is not that great. 2012 TDV8 Vogue (L322)
Post #701697 7th Oct 2024 11:37am
RRfranz
that's right
If I remember correctly, the track values ​​on my 2011 4.4 TDV8 are 9 minutes plus minus 12 minutes. To test the steering you could set it to track 0.
Post #701720 7th Oct 2024 6:30pm
MarianaWestminster
I think my next step in the steering department will be to remove the servotronic valve and check the little filter screen Graeme mentioned as well as check the valves operation.
Assuming I find no issue there I will then move on to tracking/alignment.
This does feel more mechanical to me bit then it has done on each RR I've owned.
Post #701741 7th Oct 2024 10:41pm
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
RRfranz wrote:
that's right
are you talking tow in or out RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #701745 8th Oct 2024 2:59am
Page 3 of 3 <123
