Home > My Range Rover > 5 RRs and I have to give up
Page 3 of 13 <123 4 ... 111213>
Epson Green
I think the rear subframe bushes have as much influence on the ride quality as the shock absorbers and air bags. Worth replacing if not done already. Kevin
2012 L322 Westminster 4.4 TDV8
1999 P38A 4.0 SE - Sold
Post #701399 3rd Oct 2024 6:41pm
MarianaWestminster
I've heard about that Epsom, another thing to check out.
I've been thinking out the box today about all of this.
What if the steering and engine response/feel are connected.
I'm sure I've read somewhere that the tcm prevents gearshifts etc when it detects the vehicle is turning.
What if the heavy steering is the route cause on all these cars of mine and the laggy engine is a side effect of this?
It could be that with the steering not operating correctly the rest of the car is confused on what it should be doing too?
Post #701478 4th Oct 2024 2:49pm
RRfranz
Austria 2011 Range Rover Vogue TDV8 Santorini Black
The ride quality also improved enormously on my L322 4.4TDV8 after replacing the subframe bushings.
Post #701483 4th Oct 2024 3:09pm
MarianaWestminster
I've heard that too Franz, there was nothing mentioned on the MOT but I will get under there and check them at least visually as soon as I can get back to the car/find time.
I think I should focus on steering for the moment and hope my hunch mentioned earlier regards it effecting the engine is correct.
Post #701582 5th Oct 2024 10:18pm
RRfranz
weniger Vorspur an der Vorderachse macht die Lenkung auch leichter.
Jede Spurstange mit Farbe markieren und um 1/6 Umdrehung länger machen.
1/6 Umdrehung ist circa 0 Grad 5 Minuten Spuränderung.
Auf die Farbmarkierung kann man immer zurückdrehen.
Post #701588 6th Oct 2024 6:33am
RRfranz
Sorry!
Less toe-in on the front axle also makes steering easier.
Mark each tie rod with paint and make it 1/6 turn longer.
1/6 turn is approximately 0 degrees 5 minutes track change.
You can always turn back to the color marking.
Post #701589 6th Oct 2024 6:35am
JayGee
Less toe would also make it less directionaly stable which even at the correct settings is not that great. 2012 TDV8 Vogue (L322)
Post #701697 7th Oct 2024 11:37am
RRfranz
that's right
If I remember correctly, the track values ​​on my 2011 4.4 TDV8 are 9 minutes plus minus 12 minutes. To test the steering you could set it to track 0.
Post #701720 7th Oct 2024 6:30pm
MarianaWestminster
I think my next step in the steering department will be to remove the servotronic valve and check the little filter screen Graeme mentioned as well as check the valves operation.
Assuming I find no issue there I will then move on to tracking/alignment.
This does feel more mechanical to me bit then it has done on each RR I've owned.
Post #701741 7th Oct 2024 10:41pm
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
RRfranz wrote:
that's right
are you talking tow in or out RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #701745 8th Oct 2024 2:59am
JayGee
According to the WM it's toe out 0.08 deg each side with a +/-0.1 deg tollerance so given that the wheels will pull into neg slightly under driving it's pretty neutral with quite a big tolerance. I doubt messing / adjusting this will change any steering load esp at low speed. 2012 TDV8 Vogue (L322)
Post #701757 8th Oct 2024 10:18am
MarianaWestminster
Happened upon a video which shows how I believe and remember the steering to be.
Now the vehicle shown is a pre facelift 4.4 v8 not a tdv8 but as an example it stands.
I could quite easily drive my original Westminster with one hand just like the video but this wasn't possible in the subsequent l322s I owned nor the l405 or the current l322.
I do prefer to keep both hands on the wheel when I drive, I'm only posting this as an example! Laughing
?si=e5sttlShgr9-JOIv
Post #701874 9th Oct 2024 9:50pm
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
That's how both of our 4.4TdV8's steer. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #701891 10th Oct 2024 8:50am
JayGee
I suspect the later cars drive differently from the earlier ones in areas of suspension compliance and steering to make them feel more like contempory SUV's which were more road orientated i.e firmer suspension and steering. 2012 TDV8 Vogue (L322)
Post #701892 10th Oct 2024 9:18am
MarianaWestminster
Great to know Rvbush, helps me feel like I might not be barking mad.
Wholeheartedly agree Jaygee, especially in the case of the L405 I owned.
Post #701894 10th Oct 2024 9:23am
