Home > My Range Rover > 5 RRs and I have to give up |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 691 |
I've heard about that Epsom, another thing to check out.
4th Oct 2024 1:49pm |
RRfranz Member Since: 25 Dec 2023 Location: Tirol Posts: 10 |
The ride quality also improved enormously on my L322 4.4TDV8 after replacing the subframe bushings. |
4th Oct 2024 2:09pm |
I've heard that too Franz, there was nothing mentioned on the MOT but I will get under there and check them at least visually as soon as I can get back to the car/find time.
5th Oct 2024 9:18pm |
weniger Vorspur an der Vorderachse macht die Lenkung auch leichter.
6th Oct 2024 5:33am |
Sorry!
6th Oct 2024 5:35am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
Less toe would also make it less directionaly stable which even at the correct settings is not that great. 2012 TDV8 Vogue (L322) |
7th Oct 2024 10:37am |
that's right
7th Oct 2024 5:30pm |
I think my next step in the steering department will be to remove the servotronic valve and check the little filter screen Graeme mentioned as well as check the valves operation.
7th Oct 2024 9:41pm |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 760 |
are you talking tow in or out RR 2005 4.4 petrol Any spelling mistakes are the fault of spellchecker Previous MG J2, CITROEN light 15 x 2 gone unfortunately Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar |
8th Oct 2024 1:59am |
According to the WM it's toe out 0.08 deg each side with a +/-0.1 deg tollerance so given that the wheels will pull into neg slightly under driving it's pretty neutral with quite a big tolerance. I doubt messing / adjusting this will change any steering load esp at low speed. 2012 TDV8 Vogue (L322) |
8th Oct 2024 9:18am |
Happened upon a video which shows how I believe and remember the steering to be.
9th Oct 2024 8:50pm |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 542 |
That's how both of our 4.4TdV8's steer. Drives:
10th Oct 2024 7:50am |
I suspect the later cars drive differently from the earlier ones in areas of suspension compliance and steering to make them feel more like contempory SUV's which were more road orientated i.e firmer suspension and steering. 2012 TDV8 Vogue (L322) |
10th Oct 2024 8:18am |
Great to know Rvbush, helps me feel like I might not be barking mad.
10th Oct 2024 8:23am |
