Home > Maintenance & Mods (L322) > New brakes have arrived
Page 4 of 4 <1234
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Dalex
Bridge bolt when re-installing from new has green locktite pre-applied
Manual says tighten to 30Nm
Instructions that come with the pin fitting kit says use range between 27-33Nm
Post #630343 2nd May 2022 6:51am
BigJon
Australia 2007 Range Rover Vogue TDV8 Chawton White
Rambles wrote:
Another thought
Workshop manual says bleed excess brake fluid through brake nipple.
Easier route could be to syringe excess out of the reservoir?
In any event, maybe open the reservoir whilst pushing the pistons back in and check the level....
Don't push dirty fluid from the caliper back through the hydraulic system. Always open the bleeder when retracting the pistons.
Post #658713 7th Mar 2023 5:10am
paul70
northernmonkeyjones - thanks for the brilliant guide. Did nearside Discs and pads on my 6 pot brembos on Wednesday before being rained off. Thought offside would be dead easy yesterday now I knew the method. Well it was an absolute Bas***d!!
The pins took some extreme beating to remove. Thought I was going to have to replace the caliper
The Central pin with the 13mm bolt on the back, got the bolt out OK but couldn't budge the thick pin however hard I beat it!! In the end, as the caliper was coming off to replace the Disc i managed to slot the new pads in from behind.
I didn't have a 12-point 21mm socket but luckily had a 12 point 13/16" socket in my imperial stuff for my MGB and that fitted perfectly. I had to remove these bolts with the steering turned so I could use a long breaker bar as my Aldi Impact Wrench wasn't budging them.
Post #659634 17th Mar 2023 1:03pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
northernmonkeyjones wrote:
Brakes done,
Fairly straightforward to be honest.
Will do a write up shortly. Took some pics and they are in my gallery.
This set up looks like it doesn't have the big bolt in the middle as is shown in later posts ? What is the set up on a late 2013 L405 TdV6 ?
Post #694188 10th Jun 2024 10:55am
Page 4 of 4 <1234
