Home > Maintenance & Mods (L322) > "CHECK COOLANT LEVEL" - Dashboard warning
Bluegreygreen Rangie 2
Australia
No idea what year model car the op has (fill details in Mad ) but on the tdv8 ones at least a torch will shine thru the bottle and let you see what the float is doing
Dave 2010 3.6TDV8 Autobiography
Bas remap, Egr deleted (blanked & via remap) , Cold air intake, Turbo back exhaust, Provent 200 catch can, Banks idash gauge, 275/55/R20
GAP Diagnostics
Past - 02 & 03 TD6 And an 1984 Classic
Post #565296 23rd Aug 2020 7:20pm
DrRob
I recently had mine swapped out for a new Genuine one as old one was just too dirty.
Coolant flushed and replaced with new coolant. I can now see the level clearer
I also used a Sharpie pen to highlight the min and max embossed levels on the outside of the bottle. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #565317 24th Aug 2020 7:26am
Frans@Yamorna
South Africa 2012 Range Rover Vogue SE TDV8 Zambezi Silver
Thanks.My bottle is relatively clean but I can't see a float?Seem as I will have to replace. 2012 TDV8 Vogue SE 4.4
Post #565318 24th Aug 2020 8:47am
Frans@Yamorna
How do one remove the sensor?Do you loose fluid when you remove the sensor? 2012 TDV8 Vogue SE 4.4
Post #565319 24th Aug 2020 8:56am
LFREE22
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Stornoway Grey
Is there an easy way to try replacing the sensor without having to do the whole tank?
I am also having this problem, but as the sensor is only £5 I'd be tempted to try that if possible before disconnecting and removing the whole tank...
I have tried feeling around at the bottom of the sensor, but can't seem to find an easy way to pull it out. Is there enough room for it to come out with the tank in-situ?
Post #692525 13th May 2024 1:38pm
Frans@Yamorna
I ended up replacing the bottle. 2012 TDV8 Vogue SE 4.4
Post #692718 15th May 2024 3:03pm
