Home > Maintenance & Mods (L322) > "CHECK COOLANT LEVEL" - Dashboard warning |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4311 |
I recently had mine swapped out for a new Genuine one as old one was just too dirty.
24th Aug 2020 7:26am |
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 147 |
Thanks.My bottle is relatively clean but I can't see a float?Seem as I will have to replace. 2012 TDV8 Vogue SE 4.4 |
24th Aug 2020 8:47am |
How do one remove the sensor?Do you loose fluid when you remove the sensor? 2012 TDV8 Vogue SE 4.4 |
24th Aug 2020 8:56am |
LFREE22 Member Since: 25 Apr 2023 Location: Aberdeenshire Posts: 8 |
Is there an easy way to try replacing the sensor without having to do the whole tank?
13th May 2024 1:38pm |
I ended up replacing the bottle. 2012 TDV8 Vogue SE 4.4 |
15th May 2024 3:03pm |
