![]() | Home > Maintenance & Mods (L322) > "CHECK COOLANT LEVEL" - Dashboard warning |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4311 ![]() ![]() ![]() |
I recently had mine swapped out for a new Genuine one as old one was just too dirty.
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 147 ![]() ![]() ![]() |
Thanks.My bottle is relatively clean but I can't see a float?Seem as I will have to replace. 2012 TDV8 Vogue SE 4.4 |
How do one remove the sensor?Do you loose fluid when you remove the sensor? 2012 TDV8 Vogue SE 4.4 |
LFREE22 Member Since: 25 Apr 2023 Location: Aberdeenshire Posts: 8 ![]() ![]() ![]() |
Is there an easy way to try replacing the sensor without having to do the whole tank?
I ended up replacing the bottle. 2012 TDV8 Vogue SE 4.4 |
