Home > My Range Rover > My first Range Rover some advice please
Page 5 of 5 <12345
Kiss My Carbon Footprint
United Kingdom 2011 Range Rover Autobiography TDV8 Orkney Grey
Actually, I'll qualify that - the seller does give quite detailed specifications in the item description.
But for this to be useful, we'd need to know the matching specification for your vehicle.
I fear I do not.
Warwick 2011 L322 TDV8 A/b Orkney Grey
2008 Defender 90 XS TDCi Java Black
2002 L322 TD6 Vogue Zambezi Silver (gone but not forgotten)
And one or two bikes - Ok, maybe more than one or two....
Post #686519 26th Feb 2024 7:16pm
Buellie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Orkney Grey
Many thanks again, they all seem to list the wheel nuts for all years and not 2011 specific Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #686538 26th Feb 2024 9:41pm
See eBay item no. eBay Item No. 354345426148
Post #686540 26th Feb 2024 10:06pm
Duplicate post sent in error.
Post #686541 26th Feb 2024 10:06pm
Buellie
Thanks Warwick I just bought those Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #686542 26th Feb 2024 10:31pm
Thumbs Up 2011 L322 TDV8 A/b Orkney Grey
Post #686648 27th Feb 2024 10:51pm
Buellie
So it has been a couple of weeks since buying the 2011 TDV8 and overall I am pretty happy with it.
Newish tyres and brakes, oil cooler changed, gear box serviced last year, however there are a few smallish issues.
Heated screen only partially heated, it does have a chip in it. Drivers heated seat not working. No DAB but also normal radio stations weak reception and phone connectivity crackly when speaking. TV works fine. Are these issues connected? I'm guessing aerial fault. CD player faulty but I knew this on purchase.
Bought some new wheel nuts, to remove the locking and original ones. Do the originals have a cap that you need to remove or do you just remove as one leaving the cap on the nut? Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #686876 1st Mar 2024 11:10am
Buellie
Changed the wheel nuts over the weekend. Removed the 4 locking ones and all of the others. Some were swollen and I had to hammer a 22mm socket onto them.
I would recommend everyone checks them before you need to remove them on the road.
For less than £30 it is probably best to change them every year or so as a service item. Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #687223 4th Mar 2024 9:22pm
DrRob
I did warn you about swollen nuts Laughing Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #687226 4th Mar 2024 9:33pm
Buellie
Read on Pistonheads about updated pipework on the 4.4 TDV8 to stop the oil buildup issue?
Can anyone explain this please? How can I tell if it has been done, or what should I do?
Many thanks Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #687295 5th Mar 2024 7:55pm
DrRob
Turbo drain mod. Don’t bother. Boot it above 2500rpm when warm and frequently. Easy and cheap.
Not all motors smoke. It’s a weird one tbh.
Plus drain mod requires drilling and tapping into the sump. Swarf. No ta.
Just boot it often and use the second turbo. It’s there for a reason Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #687300 5th Mar 2024 9:16pm
Buellie
Thanks Rob, I have been booting her a bit once warm and not seen any smoke at all, so I shall continue with this option Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #687304 5th Mar 2024 10:05pm
JayGee
As soon as the dash engine temp gets up to the middle give it another 15-30 mins before you 'boot it' to alow the oil temp to get up to operating temperature as this lags well behind the coolant temperature esp in winter. Also check the oil release valve in the filter housing (search previous posts) is sealing properly as leakage from here is a possible cause of the infamous smoke screen feature. 2012 TDV8 Vogue (L322)
Post #687314 6th Mar 2024 7:57am
DrRob
No smoke means you’re driving it properly and it’s not prone to oil build up. Stay on that path 👍 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #687320 6th Mar 2024 8:42am
Page 5 of 5 <12345
