Home > My Range Rover > My first Range Rover some advice please |
Buellie Member Since: 28 Jan 2024 Location: Essex Posts: 138 |
Many thanks again, they all seem to list the wheel nuts for all years and not 2011 specific Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather |
26th Feb 2024 9:41pm |
Kiss My Carbon Footprint Member Since: 19 Dec 2020 Location: Milton Keynes Posts: 119 |
See eBay item no. eBay Item No. 354345426148
26th Feb 2024 10:06pm |
Duplicate post sent in error.
Thanks Warwick I just bought those Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather |
26th Feb 2024 10:31pm |
2011 L322 TDV8 A/b Orkney Grey
27th Feb 2024 10:51pm |
So it has been a couple of weeks since buying the 2011 TDV8 and overall I am pretty happy with it.
1st Mar 2024 11:10am |
Changed the wheel nuts over the weekend. Removed the 4 locking ones and all of the others. Some were swollen and I had to hammer a 22mm socket onto them.
4th Mar 2024 9:22pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
I did warn you about swollen nuts Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
4th Mar 2024 9:33pm |
Read on Pistonheads about updated pipework on the 4.4 TDV8 to stop the oil buildup issue?
5th Mar 2024 7:55pm |
Turbo drain mod. Don’t bother. Boot it above 2500rpm when warm and frequently. Easy and cheap.
5th Mar 2024 9:16pm |
Thanks Rob, I have been booting her a bit once warm and not seen any smoke at all, so I shall continue with this option Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather |
5th Mar 2024 10:05pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3203 |
As soon as the dash engine temp gets up to the middle give it another 15-30 mins before you 'boot it' to alow the oil temp to get up to operating temperature as this lags well behind the coolant temperature esp in winter. Also check the oil release valve in the filter housing (search previous posts) is sealing properly as leakage from here is a possible cause of the infamous smoke screen feature. 2012 TDV8 Vogue (L322) |
6th Mar 2024 7:57am |
No smoke means you’re driving it properly and it’s not prone to oil build up. Stay on that path 👍 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
6th Mar 2024 8:42am |
