Home > Technical (L322) > Is it worth doing an egr deleted at 100k+?
Cinderrella
Hi all,
Have a tdv8 that I purchased recently.
When I bought it and ran a diagnostic it had the error code exhaust gas recirculation sensor c circuit low.
The car has 114k 3.6tdv8 (2010)
Local reputable company near me called midlandremap are quoting me £150 for EGR delete and a map out... States they would delete the EGR in the closed position.
Is it worth doing?
Post #685833 17th Feb 2024 9:39am
DrRob
Yes. Physical and electronic delete needed which I think they’re suggesting Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #685850 17th Feb 2024 11:50am
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
i would go for it .......that is a very good price Thumbs Up .if i was close i would take mine in to get done
Post #685862 17th Feb 2024 2:57pm
Cinderrella
Thanks guys, I spoke to them and they don't put blanking plates on... Just ag EGR delete. Is it still worth doing?
Post #685869 17th Feb 2024 5:29pm
will308f
if it was me i would….still think it is a good price
Post #685870 17th Feb 2024 5:35pm
Dutchgit
Germany 2008 Range Rover Vogue TDV8 Stornoway Grey
The EGR system is there for various reasons.
It's to do with getting the engine (or some components) temperature down under certain circumstances.
I've read quite a lot about it and decided to leave it on and functioning.
I also run a Vivaro van which has its EGR working and it has been working fine the past 266000kms.
It does benefit from "clearing the system" as I call it which is a good run down the motorway.
If it gets "deleted in one form or another your car might fail its MOT ?
Post #685883 17th Feb 2024 10:33pm
Kot
Engaging in illegal EGR removal or other emissions control system tampering in the UK can result in various penalties, including:
Fines and penalties from regulatory authorities.
The vehicle was declared unroadworthy and impounded.
Invalidated insurance coverage.
Increased emissions lead to environmental harm.
Negative impact on resale value. 2018 SE SDV8 4.4 Byron Blue
Post #685885 17th Feb 2024 11:19pm
ttrw2
I blanked the EGR on mine at ~150k miles. Straight away it idled better, the tip-in response improved (when you initially open the throttle) and MPG improved by a small amount.
And the biggest improvement is oil stays cleaner for longer.
I suspect if I’d cleaned the intake out I’d see further improvements on the first bits too.
Post #685889 18th Feb 2024 8:03am
JayGee
Irrespective of the legality or performance changes ( good or bad) the EGR valves on the 3.6 engine have a nasty habit of failing and parts being sucked into the turbo and possibly the engine so for this reason alone it probably worth doing. I'd physicaly blank them as these older EGR valves have been known ( on other cars at least) to stick open so a software delete alone won't help you. Blanking kits are cheap to buy and if you have a GAP IID tool you can buy a software update to do the software delet yourself. 2012 TDV8 Vogue (L322)
Post #685899 18th Feb 2024 11:27am
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
+1 on Jaygee's comments.
I know at least 2 3.6 engine & turbos wrecked due to egr valve head failure. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #685919 18th Feb 2024 5:03pm
Shaunj69
England 2012 Range Rover Autobiography 4.4 V8 Zambezi Silver
Just a thought!!
Dont you need the EGR for the regen of the DPF? L322 TDV8 2011 Autobiography
Working for an OE aftermarket car parts suppler
Post #685940 19th Feb 2024 11:07am
Pawl
Not on a 3.6. Thinks that's required on the 4.4TDv8 Paul,
Post #685941 19th Feb 2024 11:21am
JayGee
No DPF on the 3.6 2012 TDV8 Vogue (L322)
Post #685942 19th Feb 2024 11:21am
Gremlin500
Just out of interest, do these go through the MOT OK? Whistle “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #685944 19th Feb 2024 12:37pm
Yes they do Got - 2017 SDV8 Autobiography in Loire Blue
Post #685955 19th Feb 2024 2:16pm
