![]() | Home > Technical (L322) > Is it worth doing an egr deleted at 100k+? |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4321 ![]() ![]() ![]() |
Yes. Physical and electronic delete needed which I think they’re suggesting Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 457 ![]() ![]() ![]() |
i would go for it .......that is a very good price |
Cinderrella Member Since: 03 Jan 2024 Location: Leicester Posts: 42 ![]() ![]() |
Thanks guys, I spoke to them and they don't put blanking plates on... Just ag EGR delete. Is it still worth doing? |
if it was me i would….still think it is a good price |
Dutchgit Member Since: 17 Sep 2023 Location: Emmerich am Rhein Posts: 178 ![]() ![]() ![]() |
The EGR system is there for various reasons.
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1264 ![]() ![]() |
Engaging in illegal EGR removal or other emissions control system tampering in the UK can result in various penalties, including:
ttrw2 Member Since: 27 Dec 2015 Location: Oxfordshire Posts: 51 ![]() |
I blanked the EGR on mine at ~150k miles. Straight away it idled better, the tip-in response improved (when you initially open the throttle) and MPG improved by a small amount.
Irrespective of the legality or performance changes ( good or bad) the EGR valves on the 3.6 engine have a nasty habit of failing and parts being sucked into the turbo and possibly the engine so for this reason alone it probably worth doing. I'd physicaly blank them as these older EGR valves have been known ( on other cars at least) to stick open so a software delete alone won't help you. Blanking kits are cheap to buy and if you have a GAP IID tool you can buy a software update to do the software delet yourself. 2012 TDV8 Vogue (L322) |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 697 ![]() ![]() ![]() |
+1 on Jaygee's comments.
Shaunj69 Member Since: 25 Feb 2022 Location: Bristol Posts: 57 ![]() ![]() ![]() |
Just a thought!!
Not on a 3.6. Thinks that's required on the 4.4TDv8 Paul,
No DPF on the 3.6 2012 TDV8 Vogue (L322) |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1591 ![]() ![]() ![]() |
Just out of interest, do these go through the MOT OK? |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6743 ![]() ![]() ![]() |
Yes they do Got - 2017 SDV8 Autobiography in Loire Blue
