Home > Technical (L322) > Is it worth doing an egr deleted at 100k+?
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
Yes, mine has for the last 3 years.
Post #685956 19th Feb 2024 1:17pm
Benjerbustmills
United Kingdom 2012 Range Rover HSE TDV8 Stornoway Grey
Question?
Are the “Doom and Gloom “ merchants going to pay for your vehicle to be repaired when it’s finally been choked to death by the EGR?
Diesel engines have worked fine for years without an EGR, and they rarely fail an MoT on emissions.
EGR delete on its own is a waste of time and money in my opinion.
It needs to be blanked off.
Once blanked off, it will start “breathing” again.
It will idle better.
It will run better.
It will look after the oil better
Or will be better.
Now should you decide to tell the MOT garage, then they’ll fail it.
But, mindful that most people are pretty reserved when it comes to such clandestine acts…..
Personally….
I think you may enjoy it more!
I had the speed limiters removed off mine, and after the remap, it flies!!
Queue…..
Large smiles
Post #687862 12th Mar 2024 1:33pm
Im not sure the EGR is part of the MOT is it?
Post #687930 12th Mar 2024 11:03pm
And a 3.6 doesn't have a DPF in the UK market... Thumbs Up
Post #687931 12th Mar 2024 11:03pm
Benjerbustmills
IF the EGR is seen to be blanked or interfered with, the vehicle will fail the MOT.
3.6 TDV8 does not have a DPF
You don’t have to map out an EGR delete on a 3.6TDV8
You DO have to map out an EGR delete, on a 4.4 TDV8
If you drive a 4.4 normally after an EGR delete, the DPF should be fine.
IF it’s just used for school runs, you’ll need access to an OBD tool to do forced regeneration.
Post #687953 13th Mar 2024 9:03am
GraemeS
Shaunj69 wrote:
Dont you need the EGR for the regen of the DPF?
The EGR valve is kept closed during a regen to ensure that all the fuel-laden exhaust goes to the catalytic converter to be burnt rather than be returned to the combustion chamber where it would be burnt thus depriving the catalytic converter of fuel.
Post #687965 13th Mar 2024 10:05am
Benjerbustmills
If the EGR is blanked off it is effectively closed…. Permanently.
Therefore maximum heat will be directed towards the DPF.
It is the EGR that regulates the temperature, by opening and closing & therefore the carbon build up.
Post #687987 13th Mar 2024 1:10pm
TDV8 Paul
Yes- I did mine at 180k and she’s clicked past the 200k with no probs, definitely runs nicely and doesn’t smoke so I’d recommend it. 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #688109 14th Mar 2024 7:18pm
JayGee
Benjerbustmills wrote:
IF it’s just used for school runs,you’ll need access to an OBD tool to do forced regeneration.
Is this what the tuner told you? 2012 TDV8 Vogue (L322)
Post #688135 15th Mar 2024 9:50am
Fla
Ireland 2012 Range Rover Westminster 4.4 V8 Zambezi Silver
I have to admit I am 100% ignorant on EGR valves as I dont think I have ever had one give me trouble so may I ask a a few stupid questions?
Why do people not replace the EGR valve unit like you would an oil cooler or alternator or starter motor? Is it a pig of a job? One imagines that these units have an estimated lifespan/mileage span
Second question, does using good or bad fuel or additives make a difference to EGR Valve life does anyone know?
I hope to never see my EGR valve but I do run a 12 year old bus so you never know. Current yokes
2012 4.4 TDV8 Westminster
Subaru Sambar Pickup Tipper
2006 Disco 3
Scoobie GT wagon
Mx5 G Ltd
TT S Line
Pajero JDM Exceed
Post #688136 15th Mar 2024 10:02am
JayGee
On the 4.4 the part is expensive and difficult to get to but also very reliable so for most peolple it's still working fine at huge milages. 2012 TDV8 Vogue (L322)
Post #688138 15th Mar 2024 10:28am
Benjerbustmills
Technically you could replace the EGR’s. But, it’s a pig of a job, and they are not cheap.
It’s what the EGR does to the rest of the system.
There are quite a few videos on it on U Tube, which show the build up of crap in the inlet doughnut, and explain that , the very same build up occurs in the inlet manifolds.
Personally, I use a fuel additive, that helps to decarbonise the “Hot Side” of the turbochargers….
But, I’m led to believe that the only way to sort out the built up crud is to physically remove it!
Take the MAP sensor out and have a look at that. It should give you a good idea of what is going on inside the various intakes.
Get a decent cleaner for the sensor.
Post #688145 15th Mar 2024 11:34am
JayGee
There is only one EGR valve on the 4.4. 2012 TDV8 Vogue (L322)
Post #688147 15th Mar 2024 11:43am
Fla
This is why I love this forum, the wealth of knowledge is unprecedented. I'll keep filling my 4.4 with dipetane and good fuel and someday Ill do a turbo clean with Revive turbo cleaner and after that drive hard and fast from time to time I guess! Current yokes
2006 Disco 3
Scoobie GT wagon
Mx5 G Ltd
TT S Line
Pajero JDM Exceed
Post #688158 15th Mar 2024 4:09pm
