Home > Technical (L322) > P040D-00 (2F) EGR temperature sensor replacement
Page 10 of 10 <12345678910
shinchan
Spain
Hi guys!
After DPF removed (cutting), cleaning (120€) and reinstalled with new gaskets and 60mm clamps I moved the car to specialist to clear DPF fault cuz Gap tool not allow this operation. During the road test restricted performance appear again, also P006A-00 in Gap tool.
It seems confirmed that the intake system has a leak, but where?
Decide to perform a new smoke test again but this time well done and my suspicions were confirmed, after a while smoke appear in the valve cover...the worst and expensive failure possible in this scenario!
Now I´m reading the manual where says discard all fuel tubes once removed...I´d like to know what do you think about this. Thanks again for your support.
SMOKE TEST VIDEO: https://youtube.com/shorts/9E7I_EugG58?feature=share
Post #672838 6th Sep 2023 6:41pm
shinchan
Spain
Failure point between the plastic welding of ducts cover and valve cover.
Post #672841 6th Sep 2023 6:54pm
Mfcetin
Germany 2011 Range Rover Vogue SE TDV8 Alaska White
Baltic Blue wrote:
I have had the PO 40D fault permanently for at least 5 years, but I have never seen PO486 ?
Mike.
Do you have the yellow restricted performance warning?
I bought my RR 3 months ago and this p040d is permanently there and I started to get yellow restricted performance warning with no additional codes. I dont see much of a Performance reduction. When it happens I just keep driving, mostly coz Im on highway and have to 🙂.
It goes away on its own, without me clearing the codes.
Is it bad to drive while this yellow restricted performance warning is on?
I ordered the sensor and all tools to replace the sensor. The space on LHD rangie is even worse than UK cars, or maybe Im just to scared.
I will try with removing the cabin filter housing. 2011 Vogue SE 4.4 TDV8
Post #673586 17th Sep 2023 12:00pm
fmgl322
Germany
Finally a LHD candidate! I need to do mine and reading all the posts of RHD changes it sounds relatively easy in comparison. On LHD cars there is even less room to get in there and wiggle that sensor out, or even get near the heat shield bolts etc. Has anyone done a LHD sensor change on here by themselves, and if so, how on earth did they get near it? -------------------------
2012 4.4 TDV8 Vogue
2001 Audi A2 1.4 16V
2019 Skoda Kodiaq (don't ask...)
Post #673881 20th Sep 2023 9:10am
Mfcetin
I bought the sensor and the special tool and planning to do it on my own soon.
jaguar3 has done it on a LHD Smile 2011 Vogue SE 4.4 TDV8
Post #673882 20th Sep 2023 9:19am
jaguar3
Estonia 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
I think its even easyer to replace it on LHD cars due there is no battery box on the way. Just remove airfilter box and you can start straight away with sensor/heatshield work.
I dont think there is any difference in clearence between engine and car body.
Post #674011 22nd Sep 2023 7:20am
Mfcetin
Today I tried to do this job on my LHD Range Rover. had to remove the plastic trim where battery would be if it was RHD car.
I managed to undo one of the screws from the headshield and bent the heatshield to the side.
Cut the old sensor with a garden tool. It was the longest tool which I could reach the sensor with Smile
I got kind of happy that it was going quite ok and quickly.
However, I could not manage to undo the old nut. I tried for a few hours being extra carefull not to strip the nut.
I gave up and draw to my local mechanic to ask for help. they agreed to help if I could wait untill next friday which I accepped hapilly.
Lets see how much they will charge me for this.
I think becasue I cut the sensor and unpluged it completely I started to get the restricted performance warning (yellow) and I saw that "water in fuel sensor" fault is back. Clearing this code also clears the rest. performance.
I recently changed the cable loom for the water sensor and since than my car has been RP free Smile I hope after finishing this EGR Temp job, RP will not come back again.
-- Update
After 230 Euros (40 Euros only for Clearing Codes Smile) now I am free of this fault. I am glad that the mechanic agreed to finish the job I started Smile
I will keep an eye on fuel consumption and report if I notice any significant change.
I Am not sure if it is just placebo effect but I think my exhaust smells now better, if it makes sense Very Happy 2011 Vogue SE 4.4 TDV8
Post #675480 13th Oct 2023 12:09pm
mcspreader
United Kingdom 2010 Range Rover Vogue SE TDV8 Zermatt Silver
Am I completely missing something or is the LH exhaust manifold temperature sensor change being made to be a few metric tonnes more difficult than it should be? The LR Manual procedure is only 3 pages long and the key part is: First you take out the cabin air plenum which is secured by 2 x 13mm nuts. Then take out the fiddly plastic stuff around the battery box area. Then get up on top of the engine (I use an old bit of mattress foam in a bin bag as a comfortable rest mat) and reach down the back where access isn't easy but it's a whole lot less stressful than mining your way in from the near side of the car. While you're in there change the turbo oil feed o-rings and feel good about how efficient you are. 2011c Vogue SE 4.4 Oil Burner
1991 Hilux 2.4d MkIII. Sadly goone due to space and time.
2008 Skoda Octavia Scout
2000 TVR Tuscan 4.0
Loads of crap. Gone
Post #691885 4th May 2024 11:12am
fmgl322
Germany
Now that’s a new approach! As I’m about to do this on my LHD, this might actually be easier than I thought. There’s not much you can move out of the way on left hand drive cars to get at that sod of a sensor, so maybe the back-door route might be better than tearing my hands to bits squeezing them in from above… -------------------------
2012 4.4 TDV8 Vogue
Post #691912 4th May 2024 4:28pm
mcspreader
I still think you'll need to use a socket with extension bars directly onto the sensor but if you can just about get a hand in around the back it should be a lot easier, particularly if the battery box surround is removed and the wiring loom in that area detached from it's mountings and shoved out of the way leaving a linear route to the sensor. There is NO mention of needing to move heat shields in the workshop manual and LR are seldom shy in creating lengthy lists of ancillary tasks to get into somewhere. I had a dry run earlier and got all the way to detaching wiring loom anchors in about ten minutes or so. I could have done this but didn't have replacement tie wraps to hand and I needed the car this afternoon. I think I'll get someone to assist when my new sensor arrives as fiddling down the back while operating a ratchet seems unnecessary self flagilation.
In addition, I have Laser 4984 'Difficult Areas' Socket Set 3/8" D. I am hoping this will do instead of the JLR part or the Laser clone, both of which are a tad pricy. 2011c Vogue SE 4.4 Oil Burner
2000 TVR Tuscan 4.0
Loads of crap. Gone
Post #691925 4th May 2024 8:32pm
johnboyairey
To change rocket cover this side you need to remove the injectors and to do that you need to remove the engine mounting bolt and jack the engine up about 10-20mm with wood under the sump etc them the rear injector will come out. Then remove rocker cover and replace etc. a little tricky to thread the bolt back into engine mount so use some tape around the universal joint socket extension to make it tighter fitting.
Post #691967 5th May 2024 2:54pm
fmgl322
Germany
Job done! I finally got the sensor replaced and must say it was nowhere near as challenging as I thought (thanks to your help here!).
The worst part of the job is that bloody heat shield. Once I got that upper “lip” out of the way, it was plain sailing.
I cut the sensor down with a mini hacksaw and cracked it loose with a 1/2 inch 13mm socket and a variety of extensions.
The new sensor went in beautifully by hand before I tightened it up with the special socket. Torque setting: niceandtight.
Getting the heat shield bolts back in place is without a doubt the worst thing I’ve ever had to do on any vehicle ever. The front one right under the sensor was a pig and a half to get going, but the rear one? I gave up after several hours of lying on top of the engine trying to get it to bite in its hole. After the 14,000th time dropping it, I just gave up and left it off for the time being. I’ll go back to it another time, once I’ve devised a cunning way of locating it and starting it in its thread.
The positive part of doing this job is however a fault-free L322. At least for today.
Now to replace all brakes and the front to rear brake pipes. I splashed out and bought the pre-formed originals. By the time I would have bought all the necessary tools to make my own, the originals worked out cheaper.
Thanks again for this wonderful forum. Very Happy -------------------------
2012 4.4 TDV8 Vogue
Post #700210 16th Sep 2024 8:57pm
SpitfireS
Germany 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
To all the people that have replaced the sensor since 2019: is the new sensor holding up?
Ever since I have an IID I know I have this fault and I don't like it, even when many say it has no effect.
IOW: is it worth it to replace the broken sensor?
Question 2012 4.4TDV8
2000 Honda S2000
Post #700222 17th Sep 2024 7:38am
GGDR
mine is perfect from what was it 3 years ago
. Cheers, Greg
Post #701447 4th Oct 2024 9:56am
