Home > Technical (L322) > P040D-00 (2F) EGR temperature sensor replacement
Page 9 of 10 <12345678910>
garyRR
P00B looks related to P006. Some kind of intake leak.
P040D is standalone and will be your exhaust gas temperature sensor faulty. If you remove the engine cover and airbox, the sensor plug is easily accessible to put a multimeter on and confirm open loop. Guide here: https://www.fullfatrr.com/forum/topic67357.html
I think your next steps are as above and get a smoke test done, which will save you money over replacing lots of parts to find the cause. 2015 Range Rover Autobiography 4.4 SDV8
Post #671428 17th Aug 2023 7:56pm
jaguar3
Estonia 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
P0033-00 (2F) Turbocharger/supercharger bypass valve control - circuit open
I think this is the problem, and it cause other faults as well.
P040D is yes, standalone as Gary say. Acess is difficult true, but not impossible to replace on LHD as well
https://www.fullfatrr.com/forum/topic50202-90.html
Post #671450 18th Aug 2023 7:52am
shinchan
Spain
Hi guys! Thanks for your support...
Sensor just arrived from Bripart and ordered a smoke tester. Old sensor tested before and nothing, fried.
I decided to go ahead and waiting for the arrival of the Neilsen socket I took some pics and videos with the endoscope, it's a real nightmare! The stainless nut dropped in the abyss....
VIDEO FORCING THE HEATSHIELD: https://youtube.com/shorts/Obv_D_trd2M
Post #671676 21st Aug 2023 8:08pm
shinchan
Spain
Hi guys! Finally I could remove the old sensor and install the new...also made a smoke test without results.
Cleared all faults with IIdTool and I took the car out for a small ride. Restricted Performance again and a new message from DPF (full).
Post #671874 23rd Aug 2023 11:15pm
jaguar3
P0033-00
Post #671876 24th Aug 2023 2:15am
shinchan
Spain
Hi Jaguar,
Understood! Ordered a vacuum pump to test the bypass valve, also a tube cutter to remove the DPF.
Post #671950 24th Aug 2023 8:51pm
jaguar3
Its not a vacuum valve, its electrical solenoid valve.
There is two valves after secondary turbo: bypass valve and shut off valve. Shut off valve is vacuum, bypass is electrical.
Circuit open mean something is wrong with wiring or valve solenoid is death.
Post #671964 25th Aug 2023 7:36am
shinchan
Spain
Damn!!
Do you mean this part?
Post #671971 25th Aug 2023 8:42am
shinchan
Spain
I was convinced that it was about this:
Post #671973 25th Aug 2023 8:50am
jaguar3
shinchan wrote:
Damn!!
No.
This is prior turbocharger geometry actuator.
Post #671976 25th Aug 2023 9:30am
jaguar3
Yes of course you can check shut off valve as well to be sure its working properly.
But most likely you have some electric problem with bypass valve according fault code.
Post #671977 25th Aug 2023 9:31am
shinchan
Spain
Just removed the entire part....
and run a vacuum test of Shut Off Valve, seems to work fine.
Post #672023 25th Aug 2023 7:09pm
shinchan
Spain
and then the Solenoid:
https://youtube.com/shorts/ShEv_mvp6R8
The solenoid opens and closes, it seems to work fine but it does not perfectly seal the passage of air. If I blow through one of the ducts with the valve closed, some air always gets through.
Post #672024 25th Aug 2023 7:26pm
shinchan
Spain
What do you think about? Wiring?
Post #672025 25th Aug 2023 7:29pm
shinchan
Spain
Finally solved the problem with P0033, the connector number C1527 was unplugged.
I´ve some doubts still about the integrity of left valve cover, but now the big problem is DPF. This was almost certainly caused by me doing forced regens using my GAP IID.
Post #672091 27th Aug 2023 9:56am
