![]() | Home > Technical (L322) > P040D-00 (2F) EGR temperature sensor replacement |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
P00B looks related to P006. Some kind of intake leak.
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 194 ![]() ![]() ![]() |
P0033-00 (2F) Turbocharger/supercharger bypass valve control - circuit open
shinchan Member Since: 05 May 2015 Location: santiago de compostela Posts: 109 ![]() ![]() |
Hi guys! Thanks for your support...
P0033-00 |
Hi Jaguar,
Its not a vacuum valve, its electrical solenoid valve.
Damn!!
I was convinced that it was about this:
No. This is prior turbocharger geometry actuator. Last edited by jaguar3 on 25th Aug 2023 10:34am. Edited 1 time in total |
Just removed the entire part....
and run a vacuum test of Shut Off Valve, seems to work fine. Last edited by shinchan on 25th Aug 2023 8:36pm. Edited 1 time in total |
and then the Solenoid:
What do you think about? Wiring? |
Finally solved the problem with P0033, the connector number C1527 was unplugged.
