Home > Technical (L405) > front knuckle cracking
Page 26 of 50 <123 ... 252627 ... 484950>
fisha
Mines a '15 plate and its showing as needing the recall. Mine definitely doesn't have a full LR history or warranty. V8 or else ...
Post #671353 17th Aug 2023 9:08am
portrobc
United Kingdom 2016 Range Rover Autobiography 5.0 SC V8 Firenze Red
@ Fisha........Just spoken to the local main dealer.....they know of the issue but not the detail. Are investigating the way forward and will get back to me.
I have been told by them just this morning that not having a current warranty or full main dealer history will make no difference as this is a safety recall.
I sense this may take some time though Shocked Shocked Shocked
Rob Now running a 2016 Autobiography plus a Bentley Continental GTC
Previously ran a Lincoln Navigator and 18 XC60 T5
Before that a pile of Jeeps, Mercedes and Jaguars and Porsches, Mustang and Volvo.
Post #671356 17th Aug 2023 9:52am
fisha
I think you're right, its going to take time to get the parts into dealers / sort out the process. The same was true for the BMW and its EGR recall ... parts supply was the delay as there were so many. Quick check of mine shows no cracks at the moment. V8 or else ...
Post #671358 17th Aug 2023 10:00am
Crasher242
Sorry for the dumb question of the day, but if i dont have topix access - how do i access the online service history to check my car?
Cheers Current
Vogue SE 4.4 SDV8
Previous highlights
Many Mini's!
Audi S8
Audi A6 Avant (the petrol guzzling Bi-turbo)
Subaru H6 3.0 Estate
Peugeot 406 Coupe V6
Audi 80 Quattro Sport
Post #671364 17th Aug 2023 10:23am
put your vin number in here,
https://osh.landrover.com/ ... - .- -.
Post #671365 17th Aug 2023 10:27am
Crasher242
Thanks Stan
Not showing anything yet (mines a late 2014 model) - but will keep an eye.
Did note however that my last service has not been entered into the system so will chase up my Indy to get them to sort it out Smile Current
Vogue SE 4.4 SDV8
Previous highlights
Many Mini's!
Audi S8
Post #671367 17th Aug 2023 10:37am
154JON
United Kingdom 2015 Range Rover Vogue SDV8 Santorini Black
Land rover are saying its a bad batch of knuckles and if the batch number stamped on the knuckle is between G048840 and G058314 then they need to be replaced. As they have now admited the problem i think its time for all those who have had to cover the cost to replace the knuckles when they failed to dig out the paperwork and get on the phone to Landrover customer Services for a refund but also check to make sure that the new knuckles that were fitted do no fall within the bad batch number.
Post #671370 17th Aug 2023 10:53am
Fifth Horseman
Whilst this is a start, I would hope the VIN range is expanded over time as we have now seen later vehicles affected (at least two 2018 vehicles https://www.fullfatrr.com/forum/topic66376.html)
Also I'm not that convinced that a simple visual check as detailed in the bulletin will find all the cracked knuckles, also what happens if a crack is missed and then subsequently fails..
It would be far better to check using a crack detection spray - Method
Kit here or here
Post #671379 17th Aug 2023 11:43am
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
What’s the consensus on cause? Fatigue? Corrosion? Over-tightened from new?
Post #671391 17th Aug 2023 2:46pm
faulty casting ? ... - .- -.
Post #671395 17th Aug 2023 4:02pm
jez000
United Kingdom 2011 Range Rover Vogue SE TDV8 Bournville
Well done to all those people who put pressure on LR and VOSA to get this recall underway in the UK. 2021 P400 Silicon Silver AB
Gone 2011 Bournville TDV8 VSE
Gone 2008 Black Canadian HSE LUX
Post #671397 17th Aug 2023 4:49pm
Tdtj
Scotland 2016 Range Rover Autobiography SDV8 Santorini Black
Mines booked into pentlands on 5 September. Apparently it’s 2 hours to check for cracks. Also asked about parts. At the moment at least the parts are available. I think they will run out rather quickly 2016 4.4 diesel
Post #671421 17th Aug 2023 8:04pm
mpirie
I wonder how they will carry out the inspection?
Visual or NDT?
Maybe we should start a group buy for NDT testing kits? Whistle
Mike
Post #671422 17th Aug 2023 8:21pm
Baltic Blue
Try Googling “ crack detection spray “
Welders use it to check for cracks in welds apparently.
It is dye that highlights any cracks or flaws in metal.
Post #671432 17th Aug 2023 9:24pm
portrobc
Rob
UPDATE...........Spoken to Main Dealer all booked in, 2 stage process apparently.....inspection first to identify if there is a problem and then a rebook appointment as a priority to get any remedial work done if it is needed.
To be fair they were very accommodating which is a good sign.
HTH
Post #671451 18th Aug 2023 8:53am
