![]() | Home > Technical (L405) > Ride quality -16 SDV8 AB |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 697 ![]() ![]() |
GAP are out of ideas too. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7878 ![]() ![]() ![]() |
Posted this on the other thread…. Anyone on here?
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3157 ![]() ![]() ![]() |
That’s LandyManSam on this forum or Sams Motor and Machine on YouTube.
Ah, I guess I should have looked at the picture properly… so it is 🤣. Nothing new to add to this chat then….
Mjdronfield, would I be recalling correctly that you had dodgy accelerometer readings and if so did you replace that accelerometer on yours? |
Yes, not changed it. It was showing changing readings when the car was stationary. I can’t access it that easily without taking the mudflap off and I’m not sure it will go back on…. Did plan to swap with the one near the spare wheel to prove if it’s the wiring or the actual sensor. Phoenix was taking readings from it with his diagnostic kit, but I don’t think he’s been on here for awhile….
Ah okay, when you day changing readings do you mean alternating between 1 fixed value and another? For example switching from 1-10 then 10-1 and so on?
I can’t remember exactly, other than 1 was changing readings when still. 2011 Range Rover Vogue SE 4.4 TDV8
No worries,
Spotted a guy with a 2016 3.0 (so no dynamic reponse/anti roll control) complaining of a firm ride on Facebook.
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1157 ![]() ![]() ![]() |
IMO it is never down to the larger wheels they may make a small change but thats is all.
I'd tend to agree Cayman, this feels like a problem with the actual suspensions ability to absorb.
Thought I'd try a bounce test this evening whilst Parked up for 5 mins.
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2581 ![]() ![]() ![]() |
I just tried bouncing my L322. Parked at access height with the bonnet up, hanging onto the top radiator support and with a knee on the bumper I couldn't get more than about 5mm movement at the front and bouncing on the towbar didn't cause more than about 10mm movement at the rear. The rear shocks have done 60K kms and the fronts 40K kms. The rears will be 3/4 worn-out judging by the life of the originals and assuming that the piston seals and oil in the Bilstein shocks won't last any longer. |
