Home > Technical (L405) > Ride quality -16 SDV8 AB
Page 34 of 35 <123 ... 333435>
i agree with Mark..
you've endured this problem for five months now and you still havnt found a solution ..
time to sell.. Wink ... - .- -.
Post #670805 9th Aug 2023 9:15am
caymanblack
A nice add-on here for a well-sorted L405 should do the job! Big Cry overfinch modified
Post #670806 9th Aug 2023 9:26am
aljo
United Kingdom 2019 Range Rover Vogue SE 2.0 PHEV Santorini Black
Just a thought but have you tried putting extra weight in the car ? And I mean something substantial
Just to see if it made any difference to ride quality It might iron out some issues ? Or maybe not Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #671002 11th Aug 2023 7:49pm
MarianaWestminster
I have Aljo, moved half a ton of plastic in the back and it was a tad better with the weight in the back.
Post #671004 11th Aug 2023 8:51pm
MarianaWestminster
Just had one of my partners family members in the car and she commented:
'It's quite a smooth ride over the bumps isn't it?'
I didn't know whether to laugh or cry Big Cry
Post #671045 12th Aug 2023 5:41pm
LandyManSam
Ireland 2012 Range Rover Vogue TDV8 Santorini Black
The thing is, is that they *are* still a good ride compared with a lot of normal cars, so it was probably did feel good to your family member.
Despite the issues with my L322, it's still a nicer ride overall than my partner's small French hatchback.
I'm replacing rear dampers (currently Bilstein, new just after I purchased the car in Jan 21) again this weekend with Aerosus, just to see if it makes any difference. The car has also developed a suspension "clunk" at the rear, noticeable when jabbing the brakes at low speed. Quite possible that the harsh ride has worn bushes faster than it should have done.
As a note - mine does ride significantly better with a bit of weight in it. I collected a drum kit last weekend, and even though that was probably less than 150kg, it made a noticeable difference. Sam's Motor & Machine YouTube Channel: https://www.youtube.com/channel/UCgNSRjY0I9FCzsi9ku3ccbw
Home of the 'Cheapest 4.4 TDV8 Range Rover"
Post #672985 8th Sep 2023 2:23pm
you still not happy with the ride then MW? ... - .- -.
Post #672986 8th Sep 2023 2:27pm
JayGee
When mine came down off a 4 post lift yesterday it was noticeably less 'crashy' over road bumps at slow speeds. Something internal happening to the shocks when they are fully extended for a while? 2012 TDV8 Vogue (L322)
Post #673218 12th Sep 2023 1:50pm
OKPAULIE
United States 2016 Range Rover 5.0 SC V8 Santorini Black
I had a new compressor, valve blocks, shocks and tires and have been chasing the same issue as you. Horrible ride after all of this. I cannot figure it out and it is driving me mad! Perhaps there is a common calibration file causing this?
Post #673227 12th Sep 2023 5:44pm
JayGee
Had an adaptive dynamics error code from a front suspension height sensor which would pop up intermittently. Bought a new one but when I came to replace it noticed the plug was not properly seated so after blasting it out with wd40 and pushing it in and out a few times I got it to lock properly and have not had another fault code since. Also noticed the ride is less crashy and softer at low speeds. Wonder if any resistance in the sensor circuit is enough effect the signal but not enough to throw a fault code? 2012 TDV8 Vogue (L322)
Post #677345 5th Nov 2023 5:38pm
fisha
Plausible … I believe the damping rate is in part changed in response to how fast the rate of change is in the suspension moving. If the sensor arms were sticking / stiff and their movement had stiction and was stuttering, then that would pulse fast rates of change … which might affect the damping rate applied. V8 or else ...
Post #677352 5th Nov 2023 6:50pm
JayGee
I was refering to electrical resistance due to a poor contact in the plug and not mechanical resistance although the latter is possible. 2012 TDV8 Vogue (L322)
Post #677367 5th Nov 2023 8:38pm
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Evening all.
I recall there being a comment about someone replacing the wiring from the struts. I think it was all the wiring rather than just a portion based on what I recall reading.
JayGee's comment puts that in mind for me, and other thoughts around possible signal quality influences. Who knows, those connectors may need to be fettled to improve their connections, the wiring may become degraded over time, there's a poor connection elsewhere... or even is it weather related? that could explain the "sometimes worse than others" we've seen?
Even the 4 post lift comment (inc raising the cars height) could be just enough to disturb a connection somewhere for better or worse?
I think I may pop out and clean all of my connectors and give that a go. Little effort.
Incidentally I do find the rear of the car more crashy that the front... however there is less weight there... Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #677804 12th Nov 2023 7:56pm
JayGee
The lack of harshness has continued on mine. So much so I'm thinking it may be a bit soft at speed and an indicator the shocks are showing their age which is unsuprising at 165k miles . 2012 TDV8 Vogue (L322)
Post #678861 27th Nov 2023 6:03pm
Faulkie
United Kingdom 2019 Range Rover Vogue SDV6 Corris Grey
MariannaWestminster Hi I’m new to the group but joined to get some help on ride quality on my (new to me) 19MY 2020 Vogue SDV6 at 23000 miles. I’ve just part exchanged exactly the same car as a 17 MY on 22” wheels which had an excellent ride. Smooth as silk. The newer 2020 car on 21s is exactly as you describe yours with a jiggliness through the body especially at speeds above 50mph. I had the rear wheels balanced and they were very very slightly out but it made no difference. The wheels are all in perfect condition. Tyres are continentals which I don’t particularly like and the fronts are down to about 4mm. Steering is perfect. Have you got any further with correcting your issues?
Post #684697 3rd Feb 2024 10:37pm
