Home > Technical (L322) > Help me out with the suspension on my 'famous' 4.4TDV8 L322! |
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 |
The ZF control strategy relies on two separate sets of adaptations. There's a base adaptation map, which is what is reset by diagnostics. This is intended to allow the calibration of the adaptations to an individual gearbox, which due to manufacturing tolerances and subsequent wear levels in components will differ from unit to unit. Even small deviations in pressure and flow can cause substantially different shifting behaviour and affect the lock-up behaviour. Then there's the driver adaptations; these are constantly learned and re-learned during different drive cycles, allowing the transmission to adapt its behaviour to the driving style - but it will only work effectively on a transmission which has proper base calibration. Running the correct base adaptation re-learn procedure is essential to allow the transmission to work at its optimum; resetting the adaptations and then driving the car will allow a calibration to happen but it will never be optimal. I undertook the ZF base adaptation procedure on my BMW 645Ci. It involves a series of acceleration and coast events and some other stuff, and took over an hour and about 50mi to complete, done at 2am on a quiet motorway. It totally transformed the box's behaviour at 115K miles on old fluid. After some work on the gearbox (fluid, seals, mechatronics rebuilt) I did the same process again at 125K miles and the operation of the transmission became like a brand new unit even though the rest of the internals were 125K miles old. Annoyingly I had to do it twice the second time, as during the process a copper pulled me over and asked what the hell I was doing coasting to a stop on the hard shoulder... I explained and he ticked me off for using the hard shoulder for a non-emergency, but thanked me for being sensible enough to do it in the middle of the night and then told me to crack on, but I had to reset the adaptations and start again as I'd turned the ignition off. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica. Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500 Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten! |
30th Jun 2023 12:22pm |
chdavis Member Since: 28 Nov 2021 Location: Washington DC Posts: 44 |
A better explanation than mine.
30th Jun 2023 12:28pm |
Yeah, I was about 3/4 of the way through the process at the time, and as soon as I saw the blues go on in the rear-view I just laughed. I'd been thinking throughout the whole process that it'd be a real ballache if I got pulled over, and then it happened! 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica. Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500 Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten! |
30th Jun 2023 12:34pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3241 |
Thanks - that was the answer I was looking for 2012 TDV8 Vogue (L322) |
30th Jun 2023 12:52pm |
Privanthe Member Since: 18 Apr 2021 Location: Linlithgow Posts: 63 |
Who were you speaking to at GAP, as Patrick told me literally two days ago that this was categorically not possible. |
30th Jun 2023 4:13pm |
LOL - this is starting to read like my work emails 2012 Range Rover HSE | 2011 Range Rover Autobiography | 2010 Range Rover Sport Supercharged
30th Jun 2023 4:22pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2486 |
I was provided with a bespoke tool update which I assumed would be incorporated into the next release version. I'll check the tool later to confirm that the function is still there and take a screen print. I also had a version that included the function to recalibrate the e-diff, which I needed after the retrofit around 5 years ago but the CVD calibration inquiry was some time later.
30th Jun 2023 9:11pm |
I've run a CVD calibration on my 2012 this afternoon. 10s countdown during the process then 'process complete'.
30th Jun 2023 10:07pm |
Same but my ride is pretty good and the adaptive dampers are working correctly. I recently replaced the two front struts with OE Bilstein so I thought it would be good to run a calibration. They’re usually getting 1.5amps around town 2012 Range Rover HSE | 2011 Range Rover Autobiography | 2010 Range Rover Sport Supercharged
30th Jun 2023 10:38pm |
Been reading up about gearbox adaptation for the ZF8HP in the 4.4 TD V8 and it seems it's not the same as the ZF6HP in the 5.0. 2012 TDV8 Vogue (L322) |
1st Jul 2023 9:12am |
Thanks |
1st Jul 2023 11:54am |
Begin watching at 11:08 of this video. [url] &feature=share[/url] 2012 Range Rover HSE | 2011 Range Rover Autobiography | 2010 Range Rover Sport Supercharged 2020 Tesla Model 3 Performance, 2013 Mercedes-Benz G550, 2008 Ferrari F430, 2007 Volkswagen Touareg V10 TDI |
1st Jul 2023 6:52pm |
I don't see a description of the adaptation procedure for the ZF8HP. 2012 TDV8 Vogue (L322) |
1st Jul 2023 7:13pm |
I don’t see one from ZF either. Perhaps they got rid of the stupid drive cycle - that would be nice.
1st Jul 2023 7:15pm |
