![]() | Home > Technical (L322) > Help me out with the suspension on my 'famous' 4.4TDV8 L322! |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 718 ![]() ![]() |
I do completely understand what you are saying and have been saying in previous comments Jaygee.
Toyo Proxes SUV tyres may well have had softer sidewalls then Pirelli's as most SUV's are not anywhere near as heavy as an L322 / L405. 2012 TDV8 Vogue (L322) |
They might have been but I had Avons, Goodyear and then General grabbers on my first facelift 322 and it rode awful on all of them.
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 545 ![]() ![]() ![]() |
What I failed to add in my earlier reply is that one of our 4.4 TdV8 L322's rides on Pirelli Scorpion Zero 255 x 50 x R20 and the other on Pirelli Scorpion Verde All Seasons in the same size. The ride on the Scorpio Zero's is better, both quieter and more compliant. It's not night and day, but it is noticeable. Drives:
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 898 ![]() ![]() ![]() |
My 2004 L322 car is also much better when driving over exactly the same spots in the road as my 2011 L322, incidentally both have Pirelli Zero tyres, but the 2004 has 19" wheels, and the 2011 has 20", but what I notice the most is how the 2011 car transmits all the vibration and bumps to my steering wheel and seat - whilst the older suspension setup on the 04 car somehow soaks up most of this and continues to waft along absorbing most bumps in its stride.
telly-addict Member Since: 22 Mar 2019 Location: Morayshire Posts: 139 ![]() ![]() ![]() |
I drive an S class fairly regularly (2016-17) and it is indeed a very good air suspension setup. Not only does it handle bumps and pot holes better (with really skinny sidewalls), but it is also selectable; comfort or sport which makes a pronounced difference to the ride. It kinda ![]() 2011 TDV8 Vogue in Stornoway Grey |
RR2B Member Since: 04 Aug 2020 Location: Rowlands Castle Posts: 255 ![]() ![]() ![]() |
I've been reading this thread with interest. I too had been less than impressed with the crashy ride, particularly from the back end. A couple of weeks ago, I took the car to a 'pay and play' off-road site for the first time (great fun, and very impressive capabilities). I noticed a slight 'groaning' from the rear suspension during extreme articulation. Ever since, the on-road ride has greatly improved, with a much smoother ride. Could it be that something seizes up if the suspension is not utilised to its full extent once in a while, placing more reliance on the dampers? I could be talking rubbish, but that's just my two penn'orth!
Extending the shocks to their full length either off road, or in my case on a 4 post lift, seems to restore their function for a while. 2012 TDV8 Vogue (L322) |
RRfranz Member Since: 25 Dec 2023 Location: Tirol Posts: 13 ![]() ![]() ![]() |
Good evening, gentlemen!
Welcome to the forum!
colalowe Member Since: 11 Jul 2021 Location: Lancashire Posts: 107 ![]() ![]() ![]() |
I ended up changing my rear upper and lower arms, mainly as an easy way to change the bushes to the subframe, I had changed the 4 big subframe bushes previously and this made a small difference but changing the arms made the ride a lot better.
jamesg25 Member Since: 07 May 2020 Location: Warwickshire Posts: 24 ![]() ![]() ![]() |
Hi All,
That's fine interesting James, I await your results with interest.
James - that is highly interesting, cannot wait for you to reflash the ADCM on the choppy car and await the results |
