![]() | Home > Technical (L322) > Help me out with the suspension on my 'famous' 4.4TDV8 L322! |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2641 ![]() ![]() |
I've previously applied back level updates using my BBS Faultmate which I haven't used since getting an IIDtool so I've just grabbed both updates from the BBS site in case you find a distinct improvement. The updates are for use with the Faultmate, not the IIDtool. |
I'm still enjoying the magic carpet ride since fixing the poor wiring connection to the front height sensor a good few months back. 2012 TDV8 Vogue (L322) |
jamesg25 Member Since: 07 May 2020 Location: Warwickshire Posts: 24 ![]() ![]() ![]() |
That is interesting Graeme - please can you give me some more details/links to how I can obtain the back update from BBS?
It transpires that the BBS flash file loader which loads the flash file onto the Faultmate requires SQL Server Compact 3.5 but 3.5 won't run on Win 10, instead requiring 4.0. 3.5 doesn't install on Win 10 and with 4.0 installed the flash file loader still fails due to not finding 3.5. The Faultmate has long since been superseded by the Nanocom which is similar to the IIDtool rather than the old Faultmate. Hence I consider the Faultmate option isn't available unless I can get it to run on my Win7 VM, which I'll investigate when I have more time.
On another check I found that SQL Compact 3.5 is still available and now with both the 32 bit and 64 bit components installed, I have successfully loaded both the -AG and -AH versions onto the faultmate MSV-2. However, I don't know if my last recalibrations after fitting new shocks will be reset to factory by reloading the s/w, which I wouldn't mind anyway, so I might reload -AH for a couple of days before trying the -AG version.
My Faultmate MSV-2 prepares the file to be loaded but then doesn't offer the write menu option to write to the ecu for either the current AH version or the earlier AG version. As no error messages indicating that either the AH version is already installed or that the AG version is earlier than the installed version, I suspect that the tool's programming to write to this ecu wasn't tested/debugged.
telly-addict Member Since: 22 Mar 2019 Location: Morayshire Posts: 139 ![]() ![]() ![]() |
Doh! Well done for trying anyway. Cam
While I was not able to backward update the AD module I was able to buy a used one on ebay that was removed from a 2010 vehicle with Adaptive Dynamics. Part number AH42-18B008-AE (remember previously the car that rode smoothly was an early 60 plate car on an AH42-18B008-AG)
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7905 ![]() ![]() ![]() |
4 ride height sensors and 3 accelerometers I believe then…
Choppy-Car went in for it's MOT the other day - I noticed that one of the ride height sensors on the back was not securely attached to the lower rear suspension arm - fair amount of play in it. I wouldn't be surprised if this was having a good jiggle around on rough roads and causing mayhem on the input side of the ADCM. Hoping that a replacement here will have me sorted. will report back! |
Following this with avid interest! |
It’s still not quite right after the ride height sensor.
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
I'm back to the forum after a bit of a break, and its a shame there is still no "smoking gun" on this issue.
Yes sorry I’ve not been able to give the “smoking gun” answer - my next step was going to be rear subframe bushes as well - will report back when I have time! |
