Home > Technical (L322) > Help me out with the suspension on my 'famous' 4.4TDV8 L322!
Page 26 of 30 <123 ... 252627 282930>
chdavis
2012 Range Rover Autobiography 5.0 SC V8 Galway Green
I’ll have to put in a request - usually I get a crazy in answer in Chinese that I can’t make heads or tails of but let’s see Laughing 2012 Range Rover HSE | 2011 Range Rover Autobiography | 2010 Range Rover Sport Supercharged
2020 Tesla Model 3 Performance, 2013 Mercedes-Benz G550, 2008 Ferrari F430, 2007 Volkswagen Touareg V10 TDI
Post #667957 30th Jun 2023 1:12pm
Danb_220_2019
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
JayGee wrote:
Why doesn't it adapt over time (self calibration) ?
The ZF control strategy relies on two separate sets of adaptations. There's a base adaptation map, which is what is reset by diagnostics. This is intended to allow the calibration of the adaptations to an individual gearbox, which due to manufacturing tolerances and subsequent wear levels in components will differ from unit to unit. Even small deviations in pressure and flow can cause substantially different shifting behaviour and affect the lock-up behaviour.
Then there's the driver adaptations; these are constantly learned and re-learned during different drive cycles, allowing the transmission to adapt its behaviour to the driving style - but it will only work effectively on a transmission which has proper base calibration.
Running the correct base adaptation re-learn procedure is essential to allow the transmission to work at its optimum; resetting the adaptations and then driving the car will allow a calibration to happen but it will never be optimal.
I undertook the ZF base adaptation procedure on my BMW 645Ci. It involves a series of acceleration and coast events and some other stuff, and took over an hour and about 50mi to complete, done at 2am on a quiet motorway. It totally transformed the box's behaviour at 115K miles on old fluid.
After some work on the gearbox (fluid, seals, mechatronics rebuilt) I did the same process again at 125K miles and the operation of the transmission became like a brand new unit even though the rest of the internals were 125K miles old.
Annoyingly I had to do it twice the second time, as during the process a copper pulled me over and asked what the hell I was doing coasting to a stop on the hard shoulder... I explained and he ticked me off for using the hard shoulder for a non-emergency, but thanked me for being sensible enough to do it in the middle of the night and then told me to crack on, but I had to reset the adaptations and start again as I'd turned the ignition off. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500
Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten!
Post #667959 30th Jun 2023 1:22pm
chdavis
A better explanation than mine.
Hysterical about the police pulling you over! I worry the same thing around DC but I’ve been luck so far. Similar results - totally transformed the shifting strategy in my 2012. Which had abrupt 2-3 and 3-2 shifting.
Of course it’s tedious and stressful if you don’t live somewhere more isolated. As the procedure I posted mentions, finding a hill to use during coasting/decelerating is a huge help. Otherwise you will be rolling forever and it really don’t want to downshift to 1st gear Whistle Laughing Laughing 2012 Range Rover HSE | 2011 Range Rover Autobiography | 2010 Range Rover Sport Supercharged
Post #667961 30th Jun 2023 1:28pm
Danb_220_2019
Yeah, I was about 3/4 of the way through the process at the time, and as soon as I saw the blues go on in the rear-view I just laughed. I'd been thinking throughout the whole process that it'd be a real ballache if I got pulled over, and then it happened! 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Post #667964 30th Jun 2023 1:34pm
JayGee
Thanks - that was the answer I was looking for Thumbs Up 2012 TDV8 Vogue (L322)
Post #667965 30th Jun 2023 1:52pm
Privanthe
GraemeS wrote:
Gap added the function in response to my enquiry if they might be able to provide it at some stage. The tool invokes a standard capability of the CVD module that Gap knew about but hadn't programmed.
Who were you speaking to at GAP, as Patrick told me literally two days ago that this was categorically not possible.
Post #667993 30th Jun 2023 5:13pm
chdavis
LOL - this is starting to read like my work emails 2012 Range Rover HSE | 2011 Range Rover Autobiography | 2010 Range Rover Sport Supercharged
Post #667996 30th Jun 2023 5:22pm
GraemeS
Australia
I was provided with a bespoke tool update which I assumed would be incorporated into the next release version. I'll check the tool later to confirm that the function is still there and take a screen print. I also had a version that included the function to recalibrate the e-diff, which I needed after the retrofit around 5 years ago but the CVD calibration inquiry was some time later.
Correspondence was by email.
Post #668013 30th Jun 2023 10:11pm
Danb_220_2019
I've run a CVD calibration on my 2012 this afternoon. 10s countdown during the process then 'process complete'.
Doesn't seem to have done a lot, though. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Post #668016 30th Jun 2023 11:07pm
chdavis
Same but my ride is pretty good and the adaptive dampers are working correctly. I recently replaced the two front struts with OE Bilstein so I thought it would be good to run a calibration. They’re usually getting 1.5amps around town 2012 Range Rover HSE | 2011 Range Rover Autobiography | 2010 Range Rover Sport Supercharged
Post #668018 30th Jun 2023 11:38pm
JayGee
Been reading up about gearbox adaptation for the ZF8HP in the 4.4 TD V8 and it seems it's not the same as the ZF6HP in the 5.0. 2012 TDV8 Vogue (L322)
Post #668045 1st Jul 2023 10:12am
GraemeS
Australia
I've run a CVD calibration on my 2012..
Thanks
Post #668068 1st Jul 2023 12:54pm
chdavis
Begin watching at 11:08 of this video.
[url] &feature=share[/url] 2012 Range Rover HSE | 2011 Range Rover Autobiography | 2010 Range Rover Sport Supercharged
Post #668106 1st Jul 2023 7:52pm
JayGee
I don't see a description of the adaptation procedure for the ZF8HP. 2012 TDV8 Vogue (L322)
Post #668107 1st Jul 2023 8:13pm
chdavis
I don’t see one from ZF either. Perhaps they got rid of the stupid drive cycle - that would be nice.
Either way, it is evidence that reseting adaptations post fluid change can solve bad shift behavior, and I hope that’s something you will try! Nothing worse than a badly shifting auto. ✌️ 2012 Range Rover HSE | 2011 Range Rover Autobiography | 2010 Range Rover Sport Supercharged
Post #668108 1st Jul 2023 8:15pm
