Home > Technical (L322) > Parking Heater Remote Control |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2031 |
Because it went to an underwritter |
27th May 2011 11:10am |
wiggs Member Since: 29 May 2010 Location: Manchester Posts: 182 |
or they sold the remote ..as there about £90 from Land Rover |
27th May 2011 11:12am |
Only the Vogue TD6 has the remote start function as standard I *think*, the HSE or below has the aux heater but no receiver (although was tickable) If it was ticked as an option on the petrol then you got the whole lot. |
27th May 2011 11:48am |
Are you sure FBH = DIESEL |
27th May 2011 12:17pm |
Quite sure. |
27th May 2011 12:20pm |
27th May 2011 12:26pm |
It's not unheard of to have a faulty remote, I had one and it took me a while to figure that out - I needed to borrow a known good one to verify a working reciever and a faulty remote.
Nope |
27th May 2011 12:44pm |
Why would a FBH only run on Diesel? |
27th May 2011 12:45pm |
not saying it should ...but i wouldnt want a petrol one sat under my bonnet .
27th May 2011 2:25pm |
It doesn't just spray fuel all over the engine and chuck a match on Both the Diesel & Petrol fueled FBH work in the same way, high pressure fuel is atomised through an injector and ignited (initially) by a glow plug. Then when up to temperature the glow plug is turned off when the flame can sustain itself. There is a turbine inside to constantly feed oxygen and remove exhaust gasses - much like a jet engine. |
27th May 2011 2:30pm |
Yes ..i understand how they work ....still not keen on a petrol one though
27th May 2011 2:50pm |
Then I don't understand why you wouldnt want one? It's not like it's going to catch fire... It is used for pre-heating and Auxilliary heating if requested (via OBC) Same as the Diesel except doesnt come on automatically at low temps... |
27th May 2011 3:16pm |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
well, my new T90 remote arrived today in the post....
31st May 2011 5:49pm |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 |
I have the same problem with my T91 remote, it does not seem to work with my 2005 unit. All I get is the red LED flashing whatever I do. I might have to do the same and get a T90 remote. I got the T91 one from the bay, being sold as a newer version, but it looks like it is not compatible, or one of a faulty batch. |
6th Jun 2011 4:49pm |
