![]() | Home > Technical (L322) > Parking Heater Remote Control |
Covered here, page 2: http://www.fullfatrr.com/forum/topic3677.h...p;start=15
Added to the WiKi:
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
hi thanks for the info.
Are the post 2009 units smaller than the older type. I just took one in and am not entirely convinced by the new shape remote.....?
that's the same as the one i have just got today. it was advertised as a new unused RR remote. if it is from a newer model year, will it still work with my car?
We have the T90 receiver, the T91 remote is compatibe with the T80 - I wonder if it is also compatible with the T90?
no i haven't taken the battery out of the remote, but if you think it will help i shall do it. there is only one battery by the looks of it.
Can somebody with a post 2009 RR confirm design of their remote please? |
If your car did't come with a remote for the park heating don't you also need to fit the receiver ? I thought you couldn't just buy a remote and away you go. 2008 MY Supercharged
that's a very good point Axle!!!
i have had LR customer services email me a copy of the original build sheet for my RR.
It means it came with a remote control... The receiver lives behind the fuse board behind the rear right hand acces pannel. It is on the back of the mounting plate and the furthest right. There are two plugs going to it as per: You'll only see the top of this unit, and it'll be the other way round.
thanks for that Dan, i will get it sorted out one way or another. Current: TDV8 (3.6) RRS HSE
johnson1 Member Since: 30 Aug 2010 Location: South West Posts: 519 ![]() ![]() ![]() |
My remote is the same as in the picture |
