Home > Technical (L322) > Parking Heater Remote Control
Page 6 of 7 <1234567>
Rambles
MY11 Vogue SE is FBH factory fit.
Post #84864 1st Oct 2011 8:03am
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
i am at a loss then. all i can suggest is go through the diagram for the fuse box again, both front and rear, it should be there somewhere, even if it is a shared fuse with other items.
if not ask your dealer as it is such a new car.
good luck, let us know how you get on. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #84881 1st Oct 2011 1:02pm
mkarvine
2003 Range Rover SE Td6 Zambezi Silver
I got my remote fitted today Thumbs Up I installed T90 receiver and T91 remote. Pairing works like a charm with glovebox fuse or just by unplugging/plugging remove and pressing key for few seconds - as described in Wiki. After verifying with multimeter that remote & receiver works, I had an indie to activate parking heating option with T4 - 5 min job and remote works. Park heater activation also enabled two timer settings and manual "heat on" function from MID (I don't have NAV). T90+T91 gives impressive range, works from 600m of snowy forest.
Like discussed in D3 forums, also FFRR remote gives +12v to FBH pin1 (=pin3 in connector in trunk), no W-bus signals etc. FFRR trunk connector have pin1 +12v, pin3 signal to FBH & pin6 GND, T90 receiver just connects pins 1 & 3.
Post #104018 27th Jan 2012 10:17pm
stu
sorry to start all this again!! i kept the remotes when i swapped the car yesterday.
tried pulling the fuse (59) leaving for 10/15 secs, putting it back in and pressing the off button on the remote.................................................. nothing Sad
went into the boot, removed the three screws holding the rear fuse box so that i could get access to the module on the rear, i have read that some of you got things to work by removing the plug from the T90 module.
this is the question though, how do you remove the power plug from the T90 module??
either i am losing my marbles or there is a knack to it. i looked for a tab to press/pull but nothing.
could someone who has reoved/fitted this plug please advise me.
after the problems i had getting both remotes working on the last FFRR i was hoping for an easy ride on my new one. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #114742 25th Mar 2012 2:48pm
stu
Got it!!!... Very Happy
Like some others pulling the fuse on a TDV8 doesn't seem to work and in fact i tested the timer via the on screen display with the fuse out and it still worked????
Anyway i removed the power plug from the Webasto T90 module in the boot and hey presto two remotes paired and working fully, ready for the snow next week!!!... Rolling with laughter
The power plug is a bit of a pig as the securing tab is near the bottom of it and you will need something small to insert down the front of the plug to depress it and then pull it out.
Happy again!! Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #115665 30th Mar 2012 5:39pm
awclymm
wiggs wrote:
I have some of these ... Brand new £45 Inc p/p to UK
Ideal as a spare for your second key , one to keep in the caravan or even connect to a GSM dialler so it can be rung up[/quote]
Hi
I'd be interested in learning more about connecting the FBH remote to a gsm dialler - how does that work then?
Thanks
Andy
Post #127442 24th Jun 2012 4:51pm
stu
Best thing is to go to the Webasto website read all the info, then find your nearest dealer and speak with them!
Text modules are not new, I have been using one in my caravan for a couple of years so I can turn the heating on and find out my battery voltages etc etc Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #127577 25th Jun 2012 4:42pm
Stocky
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Fuji White
Sounds like it should work from all these posts.
Saw one today and so much neater.
Can I get one off you please, Wiggs.
Post #127601 25th Jun 2012 7:40pm
wiggs
Pm'd you Thumbs Up Bluetooth Exchange www.bluetoothexchange.co.uk
Post #127637 25th Jun 2012 10:24pm
Stocky
Monies on the way Thumbs Up Ta
Post #127905 27th Jun 2012 7:23am
awclymm
I'm getting as frustrated as other posters on this thread about the pairing of a new T91 remote....!!
I've followed all of the processes given - pulling fuse 59 in Glovebox (doesn't work) and then removing the rear fusebox and disconnecting the power to the receiver (a bit fiddly) but this doesn't work either.
Can't think what to try next??
Car is a MY2008 TDV8.
I have a T90 remote that works fine.
Post #129475 5th Jul 2012 5:45am
Realist
Wales
Yehhhhhhh happy days.
Purchased a T91 on the whim that the wife's FFRR had all that was needed to work a T91 remote so this afternoon I removed the fuse board from the rear and behind it was the controller.
I removed the power plug, waited and plugged it back in while pressing the off button on the remote, at first no go but on the 3rd attempt it worked a treat.
So remote up and running.
Thanks all. Range Rover quotes.....
The Luxury That�s More Than a Luxury.
Conquer the world, and look good doing it.
Built for the unexpected.
Over prepared, but never underdressed.
2007 Vogue SE TDV8 Epsom Green (old car).
2010 Discovery 3.0L GS Mk4 Black.
Post #377228 13th Mar 2016 3:01pm
Weegie
An old thread but I am having a problem getting the power plug out of the FBH receiver. It's the one shown on dan uk's 12th post down on the first page.
I can't see any locking clips and don't want to force it. Anyone any ideas? TIA. John
GAP iiD BT
Post #452537 30th Sep 2017 1:43pm
stu
The retainer is in the middle of the plug from memory, what I do is gently push an electricians screwdriver up the front side of the plug which is usually enough to release the catch and using the ends of the plug for grip gently pull it down and out of its housing.
Good luck.. Thumbs Up Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #452547 30th Sep 2017 3:42pm
Weegie
Thanks, Stu. Thumbs Up Will have a look later. Gave up for a while as it is a bit of a contortion to get to over the tailgate and I'm not so supple as I was. Very Happy John
GAP iiD BT
Post #452550 30th Sep 2017 3:45pm
