![]() | Home > In Car Electronics (L322) > Intermittent Sat Nav Fault---- HELP |
not sure here but you mentioned the mk4 nav unit and you have a 2007 RR, that is the wrong unit for your car V8 facelift Range Rover Autobiography 22" wheels.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
sounds like the movement of the car bounced the laser in the nav dvd unit causing it to stop working.. |
Porridge Member Since: 31 Mar 2011 Location: Dublin Posts: 51 ![]() ![]() ![]() |
The mapping has been working fine. ![]() In 753 Diagnostics mode, the system can see Satelites, but won't take a fix off them. ![]() I found a diagnostics manual online somewhere which implied that it was an ECU fault, but after my experience on Thursday I am wondering if it may be a problem with the gps antenna cable, sitting in water or somehow reduced integrity. FullFat Porridge 2007 TDV8 Vogue. 2005 VTR 1000 SP2. 2012 Hayabusa. 2006 K1200 GT 1988 ur quattro. |
My mistake. Having read all the info I can find online, I assumed it was the MK4 Ford based system.
have you tried a 2009/10 map disc with the upgrade firmware?....if not pm me.. |
The MK IV is BMW based... |
Suggest updating the firmware using the latest map disc and re-seating all the connectors. That may well cure it. If not and it turns out to be a faulty DVD unit I have a spare one which I could be persuaded to part with.
UPDATE: Tried the latest maps and firmware. Much MUCH better firmware (Thanks Scarey), but hasn't cured the "No GPS" problem. Have ordered a GPS Antenna with the FAKRA Connector on fleabay. Will check if that cures the problem. I'm not convinced it is the DVD Unit... at least I am seriously hoping that it's not !!! Keep yee posted. FullFat Porridge 2007 TDV8 Vogue. 2005 VTR 1000 SP2. 2012 Hayabusa. 2006 K1200 GT 1988 ur quattro. |
UPDATE.
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 ![]() ![]() ![]() |
The DVD unit isn't just the disc drive it contains the Nav computer too. Now I have heard any stories about these being a source of particular problems and I think that you are just unlucky on this occasion. The DVD unit is the same part for all pre 10MY touchscreen vehicles so 06MY - 09MY they are always around on eBay and I've seen a few on here too.
strange it only worked for a minute..suggests that that maybe the connections on the dvd drive might be loose and when you connected the gps antenna ,the loose connection was temporary solved..hope that makes sense.. |
pdt Member Since: 30 Nov 2009 Location: Pirbright, Surrey Posts: 42 ![]() ![]() ![]() |
Hey guys
Hmmm.
Water ingress on the similar Jaguar units is common so I would suspect this. Replacement is the answer.... |
