Home > In Car Electronics (L322) > Intermittent Sat Nav Fault---- HELP
Porridge
Ireland 2007 Range Rover Vogue TDV8 Java Black
Well, not intermittent.... more like 99.99% of the time it doesn't work!
Sat nav (MK4) has not worked since the day I bought the FFRR TDV8 2007.
Little GPS Symbol, with a red line through it, appears on the Top Left of the Nav Screen.
Then yesterday I had to drive 350km and...... blooming thing was working for 75% of the trip.... heaven!!
On the way back however, it didn't work until I went into a very tight motorway offramp curve, and way-hay, it kicked in again. Some use that was... I was nearly home.
Up to now, having done the 753 diagnostic, I was thinking that it was the SatNav ECU (DVD Drive) which was faulty... but now I am not sure.
Would an ECU fault partially rectify itself, or is it more likely that the GPS Antenna is somehow wet or otherwise faulty?
Would really appreciate any thoughts and opinions from members. Thumbs Up FullFat Porridge
2007 TDV8 Vogue.
2005 VTR 1000 SP2.
2012 Hayabusa.
2006 K1200 GT
1988 ur quattro.
Post #65090 20th May 2011 4:47pm
daveo
not sure here but you mentioned the mk4 nav unit and you have a 2007 RR, that is the wrong unit for your car V8 facelift Range Rover Autobiography 22" wheels.
Post #65091 20th May 2011 4:55pm
sounds like the movement of the car bounced the laser in the nav dvd unit causing it to stop working..
Post #65094 20th May 2011 4:58pm
Porridge
The mapping has been working fine. Smile albeit a 2007 set of maps.
In 753 Diagnostics mode, the system can see Satelites, but won't take a fix off them. Sad
I found a diagnostics manual online somewhere which implied that it was an ECU fault, but after my experience on Thursday I am wondering if it may be a problem with the gps antenna cable, sitting in water or somehow reduced integrity. FullFat Porridge
2007 TDV8 Vogue.
2005 VTR 1000 SP2.
2012 Hayabusa.
2006 K1200 GT
1988 ur quattro.
Post #65152 21st May 2011 8:29am
Porridge
My mistake. Having read all the info I can find online, I assumed it was the MK4 Ford based system.
[/img] FullFat Porridge
2007 TDV8 Vogue.
2005 VTR 1000 SP2.
2012 Hayabusa.
2006 K1200 GT
1988 ur quattro.
Post #65154 21st May 2011 8:42am
have you tried a 2009/10 map disc with the upgrade firmware?....if not pm me..
Post #65156 21st May 2011 8:51am
SteveMFr
Site Sponsor
The MK IV is BMW based... Razz
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #65529 24th May 2011 7:00am
mzplcg
Suggest updating the firmware using the latest map disc and re-seating all the connectors. That may well cure it. If not and it turns out to be a faulty DVD unit I have a spare one which I could be persuaded to part with.
Part numbers as on the label you show are
YIB500070
462100 - 8318
Denso unit from a 2007 Vogue.
Dom
Post #65565 24th May 2011 10:55am
Porridge
Dom
UPDATE:
Tried the latest maps and firmware.
Much MUCH better firmware (Thanks Scarey), but hasn't cured the "No GPS" problem.
Have ordered a GPS Antenna with the FAKRA Connector on fleabay. Will check if that cures the problem.
I'm not convinced it is the DVD Unit... at least I am seriously hoping that it's not !!!
Keep yee posted. FullFat Porridge
2007 TDV8 Vogue.
2005 VTR 1000 SP2.
2012 Hayabusa.
2006 K1200 GT
1988 ur quattro.
Post #66325 30th May 2011 9:56am
Porridge
UPDATE.
New GPS Antenna worked for 1 minute, then back to non-functional.
The real-time positioning works OK, based on gyro and speed I guess, but as soon as the FFRR goes on a road which isn't on the maps it goes out of sync.... never to return.
Pity I can't talk directly to Land Rover or Denso about it, and the Dealerships really don't give a toss.
I would like to have it working, but in reality it's not worth the cost of replacing the DVD Unit. If this is going to be a regular fault with the Sat Nav in 2007 on models, wouldn't you think Land Rover would like to get the data so that they can head off the negative vehicle relaibility reputation that they have long suffered from?
OK, probably don't care that much! FullFat Porridge
2007 TDV8 Vogue.
2005 VTR 1000 SP2.
2012 Hayabusa.
2006 K1200 GT
1988 ur quattro.
Post #68047 10th Jun 2011 12:52pm
stevegt
United Kingdom 2006 Range Rover Autobiography 4.4 V8 Cairns Blue
The DVD unit isn't just the disc drive it contains the Nav computer too. Now I have heard any stories about these being a source of particular problems and I think that you are just unlucky on this occasion. The DVD unit is the same part for all pre 10MY touchscreen vehicles so 06MY - 09MY they are always around on eBay and I've seen a few on here too.
Steve 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #68175 11th Jun 2011 11:42am
strange it only worked for a minute..suggests that that maybe the connections on the dvd drive might be loose and when you connected the gps antenna ,the loose connection was temporary solved..hope that makes sense..
Post #68180 11th Jun 2011 12:12pm
pdt
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Hey guys
I am having exactly the same issue.
The little GPS symbol has a red line through it.
Bought a flea bay fakra antenna and still no joy.
Have done the 2009 firmware...
Anyone have any other thoughts?
Or have a spare DVD unit I can try to see if the problem is in there?
Cheers
pdt
Post #70385 28th Jun 2011 6:50pm
Porridge
Sat Nav - No GPS... The Plot Thickens
Hmmm.
Changed the Antenna (told you that before), and it didn't fix the problem.
Today I received a 2nd hand unit (which came with an official 2010 Disc!), but still no GPS.
WTF!!!! FullFat Porridge
2007 TDV8 Vogue.
2005 VTR 1000 SP2.
2012 Hayabusa.
2006 K1200 GT
1988 ur quattro.
Post #165000 15th Jan 2013 6:36pm
Water ingress on the similar Jaguar units is common so I would suspect this. Replacement is the answer....
Post #165008 15th Jan 2013 6:47pm
