Home > In Car Electronics (L322) > Intermittent Sat Nav Fault---- HELP |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
not sure here but you mentioned the mk4 nav unit and you have a 2007 RR, that is the wrong unit for your car V8 facelift Range Rover Autobiography 22" wheels.
20th May 2011 5:55pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35114 |
sounds like the movement of the car bounced the laser in the nav dvd unit causing it to stop working.. |
20th May 2011 5:58pm |
Porridge Member Since: 31 Mar 2011 Location: Dublin Posts: 51 |
The mapping has been working fine. albeit a 2007 set of maps. In 753 Diagnostics mode, the system can see Satelites, but won't take a fix off them. I found a diagnostics manual online somewhere which implied that it was an ECU fault, but after my experience on Thursday I am wondering if it may be a problem with the gps antenna cable, sitting in water or somehow reduced integrity. FullFat Porridge 2007 TDV8 Vogue. 2005 VTR 1000 SP2. 2012 Hayabusa. 2006 K1200 GT 1988 ur quattro. |
21st May 2011 9:29am |
My mistake. Having read all the info I can find online, I assumed it was the MK4 Ford based system. 2007 TDV8 Vogue. 2005 VTR 1000 SP2. 2012 Hayabusa. 2006 K1200 GT 1988 ur quattro. |
21st May 2011 9:42am |
have you tried a 2009/10 map disc with the upgrade firmware?....if not pm me.. |
21st May 2011 9:51am |
The MK IV is BMW based...
24th May 2011 8:00am |
Suggest updating the firmware using the latest map disc and re-seating all the connectors. That may well cure it. If not and it turns out to be a faulty DVD unit I have a spare one which I could be persuaded to part with.
24th May 2011 11:55am |
UPDATE: Tried the latest maps and firmware. Much MUCH better firmware (Thanks Scarey), but hasn't cured the "No GPS" problem. Have ordered a GPS Antenna with the FAKRA Connector on fleabay. Will check if that cures the problem. I'm not convinced it is the DVD Unit... at least I am seriously hoping that it's not !!! Keep yee posted. FullFat Porridge 2007 TDV8 Vogue. 2005 VTR 1000 SP2. 2012 Hayabusa. 2006 K1200 GT 1988 ur quattro. |
30th May 2011 10:56am |
UPDATE.
10th Jun 2011 1:52pm |
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 |
The DVD unit isn't just the disc drive it contains the Nav computer too. Now I have heard any stories about these being a source of particular problems and I think that you are just unlucky on this occasion. The DVD unit is the same part for all pre 10MY touchscreen vehicles so 06MY - 09MY they are always around on eBay and I've seen a few on here too.
11th Jun 2011 12:42pm |
strange it only worked for a minute..suggests that that maybe the connections on the dvd drive might be loose and when you connected the gps antenna ,the loose connection was temporary solved..hope that makes sense.. |
11th Jun 2011 1:12pm |
pdt Member Since: 30 Nov 2009 Location: Pirbright, Surrey Posts: 42 |
Hey guys
28th Jun 2011 7:50pm |
Hmmm.
15th Jan 2013 7:36pm |
Water ingress on the similar Jaguar units is common so I would suspect this. Replacement is the answer.... |
15th Jan 2013 7:47pm |
