![]() | Home > Maintenance & Mods (L322) > turbos down... |
You don't need new turbo's - you need a new mechanic |
ergobyte Member Since: 03 Apr 2022 Location: bordeaux Posts: 124 ![]() ![]() ![]() |
I'd agree with that, there doesn't at this stage seem to be anything other than normal oil usage. If you are at all worried, you can get a cheap boroscope from Amazon or fleabay and poke it down the hose to check for wear or pooling of oil.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4313 ![]() ![]() ![]() |
You are being ripped off with total and utter rubbish. Everything the others have said is spot on.
Alas I agree, but getting my hand on a new independent mechanic that know his way around a 2012 TDV8 is quite hard around these parts.
Drive to the UK for a short holiday and take it to a specialist nr the south coast |
Yeah, I might just do that.
IME it's not a practical proposition to own one of these without easy access to a specialist. Even I'm struggling with this aspect of ownership living in the capital city of the UK. 2012 TDV8 Vogue (L322) |
... and the money to make it happen ![]() |
www.glenrands.co.uk is who I use. 20mins from Portsmouth port ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 194 ![]() ![]() ![]() |
What? How the mechanic can say something like that without ensure? We have gravity on the earth, and if you have remarkable oil leakage from turbos, where this oil going at first? Of course on the bottom, in lower point of intake. It takes 10 minutes to ensure.
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
Sylvan,
jagracer Member Since: 14 Aug 2021 Location: Norfolk Posts: 113 ![]() ![]() ![]() |
If it does not smoke on the over run, its OK. I had an early Classic R/R with a Mazda Perkins 3 litre turbo charged engine in the mid nineties which pushed oil out where ever it could. The firm that did the conversion said it was normal, and the engine would last 400k miles before looking at it. The main reason it pushed oil out was a lack of Waste Gate, and over pressuring the inlet. Luckilly modern engines do not seem to have these problems, except, perhaps the 3.6 tdv8 engine. Landrovers that do not leak oil are not common in my experience, and I have four of them currently. |
Jaguar3 makes a good point - if the intercooler has a lot of oil in it (>0.5litre) then you have a problem, if not, get your car back & enjoy. |
