Home > Maintenance & Mods (L322) > turbos down... |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3051 |
You don't need new turbo's - you need a new mechanic 2012 TDV8 Vogue (L322) |
27th Jan 2023 7:31pm |
ergobyte Member Since: 03 Apr 2022 Location: bordeaux Posts: 123 |
"it needs some intelligence to undestand you may not have enough" |
27th Jan 2023 7:59pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
I'd agree with that, there doesn't at this stage seem to be anything other than normal oil usage. If you are at all worried, you can get a cheap boroscope from Amazon or fleabay and poke it down the hose to check for wear or pooling of oil.
27th Jan 2023 8:12pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4287 |
You are being ripped off with total and utter rubbish. Everything the others have said is spot on.
27th Jan 2023 8:44pm |
Alas I agree, but getting my hand on a new independent mechanic that know his way around a 2012 TDV8 is quite hard around these parts.
28th Jan 2023 10:04am |
Drive to the UK for a short holiday and take it to a specialist nr the south coast Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
28th Jan 2023 10:19am |
Yeah, I might just do that.
28th Jan 2023 10:44am |
IME it's not a practical proposition to own one of these without easy access to a specialist. Even I'm struggling with this aspect of ownership living in the capital city of the UK. 2012 TDV8 Vogue (L322) |
28th Jan 2023 11:35am |
... and the money to make it happen "it needs some intelligence to undestand you may not have enough" |
28th Jan 2023 11:50am |
www.glenrands.co.uk is who I use. 20mins from Portsmouth port Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silcon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
28th Jan 2023 12:09pm |
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 193 |
What? How the mechanic can say something like that without ensure? We have gravity on the earth, and if you have remarkable oil leakage from turbos, where this oil going at first? Of course on the bottom, in lower point of intake. It takes 10 minutes to ensure.
28th Jan 2023 5:17pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
Sylvan,
28th Jan 2023 5:41pm |
jagracer Member Since: 14 Aug 2021 Location: Norfolk Posts: 113 |
If it does not smoke on the over run, its OK. I had an early Classic R/R with a Mazda Perkins 3 litre turbo charged engine in the mid nineties which pushed oil out where ever it could. The firm that did the conversion said it was normal, and the engine would last 400k miles before looking at it. The main reason it pushed oil out was a lack of Waste Gate, and over pressuring the inlet. Luckilly modern engines do not seem to have these problems, except, perhaps the 3.6 tdv8 engine. Landrovers that do not leak oil are not common in my experience, and I have four of them currently. |
28th Jan 2023 8:18pm |
Jaguar3 makes a good point - if the intercooler has a lot of oil in it (>0.5litre) then you have a problem, if not, get your car back & enjoy. |
28th Jan 2023 8:51pm |
