![]() | Home > Maintenance & Mods (L322) > turbos down... |
ergobyte Member Since: 03 Apr 2022 Location: bordeaux Posts: 124 ![]() ![]() ![]() |
Well I guess I'm running out of luck with my 2012 4.4 TDV8 Vogue. At 170 000Km it seems my turbo(s?) are leaking oil.
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 ![]() ![]() ![]() |
Seems like they have plenty of good reviews on google, the only concern if you are not in the UK is the 21-day core exchange https://www.google.com/search?client=firef...n+Limited# 2007 TDV8 VSE
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 372 ![]() ![]() ![]() |
If you are replacing the turbos get them to replace the turbo oil feed pipes at the same time they can get blocked up limiting or stopping oil feed to the turbos causing premature wear.
It would be standard procedure during a turbo replacement to make sure all oil and water feed and drain lines are clear. 2012 TDV8 Vogue (L322) |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 830 ![]() ![]() ![]() |
Let’s hope it’s not like this….
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 754 ![]() ![]() |
You might want to do a bit more investigating first.
@cass - wise words. |
Thank you all for those wise words. it cheered me up a little.
Is the engine coming out for other reasons? 2012 TDV8 Vogue (L322) |
here are the pics :
Normal to have oil residue in any turbo charged car's intake. Whey is the engine coming out? 2012 TDV8 Vogue (L322) |
I'm still negociating the work to be done and the turbo prices (refurb or new) ... I'm thinking no earlier than mid february.
So let me get this clear - you are taking the engine out and changing the turbo's due to a bit of oil in the intake pipes? 2012 TDV8 Vogue (L322) |
you've still not said why the engine needs to come out?
