Home > Technical (L322) > Parking Heater Remote Control
Page 2 of 7 <1234567>
johnson1 wrote:
My remote is the same as in the picture Thumbs Up (2011.5MY)
thanks Thumbs Up
Post #64779 19th May 2011 3:17pm
stu
i saw one of these new remotes sold for over £120 on ebay the other night... Shocked
i may just have one going for sale to fund the purchase an older shape one to see if that works in my car. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #64818 19th May 2011 5:40pm
nbunney
Stu
Don't forget I've got 1 of the older 1's for sale Thumbs Up
Post #64994 20th May 2011 10:09am
wiggs
[/quote]
I have some of these ... Brand new £45 Inc p/p to UK
Ideal as a spare for your second key , one to keep in the caravan or even connect to a GSM dialler so it can be rung up
Post #65265 22nd May 2011 2:52pm
Hi Wiggs
What year do those remotes work on ? will they work on my 2006MY ? 2008 MY Supercharged
Post #65346 23rd May 2011 9:30am
wiggs
I have no idea Shocked
They are the T91 remotes ...so im suspecting the newer sport / FFRR and Disco 4 from proberly late 2009 / 2010 onwards
Post #65359 23rd May 2011 10:48am
Well, I just looked on the Wabasto website and they say the T91 is compatible with the T80 Question
Maybe I should give it a pun and see if it works. 2008 MY Supercharged
Post #65363 23rd May 2011 11:28am
wiggs
I can send you one if you want to try it Thumbs Up
If it dont work ..you can send it back ..
There easy to pair ...just pull the appropriate fuse ...then when putting it back in hold the off button on the remote ....the light on the remote should then light up
Post #65368 23rd May 2011 11:53am
stu
i have one of these and i can't get it to work... Sad Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #65374 23rd May 2011 12:07pm
And you do have a Telestart unit in the back on the right hand side ? 2008 MY Supercharged
Post #65390 23rd May 2011 1:46pm
dan_uk_1984
Maybe someone could get in touch with Webasto and ask for clarification? It would be handy to have an "official" remote compatibility guide...
Post #65396 23rd May 2011 1:54pm
stu
yes i do have the little box (telestart) in the right hand cubby hole.
i did contact webasto last week and i have had no reply... Sad Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #65458 23rd May 2011 5:18pm
dan_uk_1984
I've got a contact there, I'll dig her our and drop her a line for you...
Post #65459 23rd May 2011 5:22pm
stu
thanks that would be very kind of you!!.... Thumbs Up Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #65461 23rd May 2011 5:27pm
stu
hi guys, got this reply from webasto today.
Hi Stuart.
Unfortunately if the heater was factory fitted you won’t be able to use just any second hand remote and get it reprogrammed by a dealer.
The remote has to be Land Rover specific, this is because all automotive companies use there own specific can-bus communication language.
The remote would have to be purchased from Rover as Webasto UK and there dealers are aftermarket/retro fit.
The product is factory fitted (OEM) so this makes it a Rover part.
Many thanks
Technical Support Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #65588 24th May 2011 5:40pm
