Home > Maintenance & Mods (L322) > Propshaft Centre Bearing Failed
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Those that have been following my project pages will know that I have already changed the propshaft centre bearing once. Its only covered about 2000 miles since being changed but it's self destructed already.
I bought it from Bearmach and they have gone into administration so fat chance of claiming on any warranty.
 Christian.
Current Cars
2011 Range Rover Vogue SE
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #643591 22nd Sep 2022 12:20pm
Full-fat-Lance
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Orkney Grey
If you paid by credit card might you be able to make a claim against then under (from memory) section 75
Post #643637 22nd Sep 2022 8:22pm
Caesium
It has got to be over £100 for the section 75 apparently. Christian.
Current Cars
2019 BMW X4
or
Post #643672 23rd Sep 2022 8:22am
pcourtney
which company did you use in the end for the centre bearing ??
Post #648131 15th Nov 2022 11:31am
It's been said on here a few times that just replacing the bearing can be false economy, I dare say some have lasted a reasonable time but a lot have had premature failures, a genuine new complete propshaft is the only way to ensure longevity.. Thumbs Up Pete
Post #648134 15th Nov 2022 12:37pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
From what i have seen on various cars is people change the center bearing only and when they split the prop to get the old one off they never mark it up so when it goes back together is is out of balance. plus they do not change the UJ's either.
When mine went i went down the road of a new prop just because i needed the car back on the road and i had to wait for the UJ's to referb the original.
I have now refurbished the original and both UJ's were worn which probably contributed to the failure. 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #648136 15th Nov 2022 12:57pm
GGDR
Jayk69 what's a new prop shaft cost pls for the part?
. Cheers, Greg
Post #648168 15th Nov 2022 7:02pm
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
https://www.advancedfactors.co.uk/propshafts-13464-c.asp
Post #648171 15th Nov 2022 7:16pm
dhallworth
A new propshaft from LR is in the region of 800 quid.
The centre bearing is available for £133 but I’m not sure if it’s compatible with the later cars.
Post #648172 15th Nov 2022 7:18pm
Caesium
I marked mine but there is no need as the centre joint only goes together one way. There is a double width spline. Christian.
Current Cars
2019 BMW X4
or
Post #648238 16th Nov 2022 1:49pm
Jayk69
Christian, i was not suggesting you had not done the job proper i have seen your videos so know how studious you are. i have to say i did not clock the double spline on mine!! everyday is a learning day. Thumbs Up 2012 Vogue 4.4 TDV8 - Current
Post #648316 17th Nov 2022 8:40am
