Home > Maintenance & Mods (L322) > Propshaft Centre Bearing Failed |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 453 |
Those that have been following my project pages will know that I have already changed the propshaft centre bearing once. Its only covered about 2000 miles since being changed but it's self destructed already.
22nd Sep 2022 12:20pm |
Full-fat-Lance Member Since: 06 Feb 2022 Location: Essex Posts: 123 |
If you paid by credit card might you be able to make a claim against then under (from memory) section 75 |
22nd Sep 2022 8:22pm |
It has got to be over £100 for the section 75 apparently. Christian.
23rd Sep 2022 8:22am |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 841 |
which company did you use in the end for the centre bearing ?? |
15th Nov 2022 11:31am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8363 |
It's been said on here a few times that just replacing the bearing can be false economy, I dare say some have lasted a reasonable time but a lot have had premature failures, a genuine new complete propshaft is the only way to ensure longevity.. Pete
15th Nov 2022 12:37pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 |
Jayk69 what's a new prop shaft cost pls for the part?
15th Nov 2022 7:02pm |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 526 |
15th Nov 2022 7:16pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3143 |
A new propshaft from LR is in the region of 800 quid.
15th Nov 2022 7:18pm |
I marked mine but there is no need as the centre joint only goes together one way. There is a double width spline. Christian. Current Cars 2011 Range Rover Vogue SE 2020 BMW M4 Competition 2019 BMW X4 My RR Blog: www.facebook.com/L322Project or https://www.fullfatrr.com/forum/topic61540.html |
16th Nov 2022 1:49pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
Christian, i was not suggesting you had not done the job proper i have seen your videos so know how studious you are. i have to say i did not clock the double spline on mine!! everyday is a learning day. 2012 Vogue 4.4 TDV8 - Current
17th Nov 2022 8:40am |
