![]() | Home > Maintenance & Mods (L322) > Propshaft Centre Bearing Failed |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
Those that have been following my project pages will know that I have already changed the propshaft centre bearing once. Its only covered about 2000 miles since being changed but it's self destructed already.
Current Cars 2011 Range Rover Vogue SE 2020 BMW M4 Competition 2019 BMW X4 My RR Blog: www.facebook.com/L322Project or https://www.fullfatrr.com/forum/topic61540.html |
Full-fat-Lance Member Since: 06 Feb 2022 Location: Essex Posts: 131 ![]() ![]() ![]() |
If you paid by credit card might you be able to make a claim against then under (from memory) section 75 |
It has got to be over £100 for the section 75 apparently. Christian.
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 900 ![]() ![]() ![]() |
which company did you use in the end for the centre bearing ?? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8529 ![]() ![]() ![]() |
It's been said on here a few times that just replacing the bearing can be false economy, I dare say some have lasted a reasonable time but a lot have had premature failures, a genuine new complete propshaft is the only way to ensure longevity.. |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Jayk69 what's a new prop shaft cost pls for the part?
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3192 ![]() ![]() ![]() |
A new propshaft from LR is in the region of 800 quid.
I marked mine but there is no need as the centre joint only goes together one way. There is a double width spline. Christian. Current Cars 2011 Range Rover Vogue SE 2020 BMW M4 Competition 2019 BMW X4 My RR Blog: www.facebook.com/L322Project or https://www.fullfatrr.com/forum/topic61540.html |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
Christian, i was not suggesting you had not done the job proper i have seen your videos so know how studious you are. i have to say i did not clock the double spline on mine!! everyday is a learning day. |
