Home > Technical (L322) > Venture cam cradle voltage
Page 3 of 3 <123
daveo
now i was told that the image uses 2.4ghz to send the video and the bluetooth gives the commands to the unit V8 facelift Range Rover Autobiography 22" wheels.
Post #62568 3rd May 2011 10:52pm
Blubberman
Wales 2005 Range Rover Vogue 4.4 V8 Java Black
Another forum mentioned this , so It could be true , I don't know personally . Still trying to get my head around it all . Confused
I was wondering about using my spare camera as a permanent reversing camera , I know that when I put a 7.2 v PSU on the camera terminals when the batteries were goosed , the camera powered up and the red leds worked ok. I was wondering about mounting my spare camera down by the tow bar somewhere on a permanent voltage feed , so I can switch to it when reversing . May be useful because my reversing sensors only work when the gremlin master allows it .
Post #62572 3rd May 2011 11:11pm
2.4ghz is the bluetooth frequency dave...the commands are on the 435mhz frequency.. ... - .- -.
Post #62578 4th May 2011 6:51am
stu
my cam just arrived today. brand new in the original box complete with bracket. put it in the holder, took a couple of mins then it said on display cam charging.
it is fully charged now and works a treat, i love ebay bargains and my FF is now complete as it left the factory again. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #64547 18th May 2011 5:54pm
stu
is it ok to leave the cam in the holder all the time, or when it is charged should i take it out? Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #64823 19th May 2011 5:53pm
I think it's a case of use it or lose it! I am going to run my one down once a month if I remember. I don't think it's healthy for any battery to be constantly on charge and never used. Previously..
Post #64875 19th May 2011 7:41pm
stevenA
2002 Range Rover Vogue Td6 Zermatt Silver
Just to pick up on Blubbermans post from some time back, I would like to confirm that these units are fairly straightforward to repair once the batteries are dead.
Mine was from a 2007, and so may be different from Blubbermans, but it uses 750mAh AAA Nimh batteries, not nicads. Tagged 800 mAH ones are easily found on the web, and much easier to solder. If you go down this route remember to recover the thermistor which is scotched to the old pack!. The only disadvantage with this method, is I could not reuse the fusible link that is on the original pack.
The original packs are made by GP, but I could not source anywhere.
The Venture Cam is actually held together by 3 clips, 1 on each side near the top (camera end) and 1 centrally at the bottom (plus, of course, the sealant). To open, I used a swiss army knife screwdriver head inserted 2/3 down one side and gently twisted. Once the seal is broken, slide it to the bottom until you hit the tab, and then push the tab with another slim knife to release. The other 2 will then pop out.
Although I could rejuvenate the batteries, they were gone (0 - 0.2v /cell on most). Pop the new ones in, seal and clip back togeher and it works great (and there are no visible signs of it ever having been touched.
Hope this helps!
Post #83044 21st Sep 2011 10:13pm
robbo770
Scotland 2005 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Anyone got the wiring from in the FFRR available for the docking station!!!
I am retro fitting into my Discovery 3, all done bar this bit so I can get the twisted pair and power hooked in.
anyone able to supply even a photo of the plug and the cables that run into the cradle.
thanks Rob Current vehicles
4.2 SC FFRR RSE 2010- facelift
Range Rover Evogue Dynamic Lux
Gone
Rejected RRS my14.5 nightmare
Disco B4 XXV convert
Freelander 06 SE
06 RFFRR 4.2 SC Vogue RSE
Audi A8 4.2Tdi Quattro (hated with a vengence!!)
54 FFRR 2005 model V8 4.4 Cobra Variant
53 Mitsubishi Shogun V6
Post #220609 4th Nov 2013 1:10am
robbo770
Urgent Venture cam plug pictures required
can someone supply several photos of the venture cam wiring plug
trying to source a supplier but need some really good photo's of it to aid the supply.
thanks
rob Thumbs Up Current vehicles
Gone
Freelander 06 SE
Post #224552 22nd Nov 2013 1:30pm
Page 3 of 3 <123
