![]() | Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix |
Best to replace the oil cooler as it can warp and leak again. 2012 TDV8 Vogue (L322) |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 775 ![]() ![]() ![]() |
Not wishing to go against the grain of popular opinion...... but...... ![]() I only changed my gaskets and O-rings on New Years day! Had the cooler off, cleaned and visually inspected. I didn't change the oil cooler, as I felt that the stories about warped coolers might just be a bit of a sales technique - most garages (including independents) like to go the easy route and take your money for unbolting/replacing parts. Nearly a year down the line and approaching 10kmiles later - everything is still 'hunky dory'! In short, the whole sorting the cooler leak 'thing' cost me £50!! The older I get, the more I realise that people confuse wrinkles for wisdom ![]() |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2566 ![]() ![]() ![]() |
66,000 kms since I changed just the gaskets. I wouldn't be surprised if they leak again as they were the original part number gaskets rather than the new part numbers which hopefully are made of more heat-resistant material. My EGR is currently still functional so heat from the EGR cooler is still heating the oil cooler. |
blackpool Member Since: 14 Aug 2022 Location: Blackpool Posts: 24 ![]() ![]() ![]() |
Hello @JMC
Thanks for the heads-up 'blackpool'.... |
Westridge177 Member Since: 12 Oct 2021 Location: Birmingham Posts: 23 ![]() ![]() |
Well done on the tip of leaving the first seal in place and changing the inner one first, I’m a boiler engineer and was getting ready to drop that one instead of wrapping tape around an oily component. |
Smoggie35 Member Since: 21 Nov 2022 Location: North Yorkshire Posts: 9 ![]() ![]() ![]() |
Guys,
Jimmies Member Since: 19 Jan 2022 Location: N.Yorks Posts: 24 ![]() ![]() ![]() |
Just did this myself.
@Jimmies.
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 ![]() ![]() ![]() |
Hi guys I have had all the same issues here symptoms burning oil smell smoke from back of engine only when car is warmed up horrible fumes in cabin so had oil cooler replaced 3 weeks ago but still the same fumes and smoke so now thinking its the pipe that feeds into the back of oil cooler the o rings as Craig said at start of this thread. Is this the same setup then for the L405 as the L322 this pipe that feeds the back of oil cooler causing the issue.
Yes. |
RBFFRR Member Since: 19 Feb 2022 Location: Blackburn Posts: 4 ![]() ![]() ![]() |
Can anyone tell me what size bolt is used for the feed pipe at the rear? Mine has snapped!! Getting a new cooler, does it come with the bolts for the pipe? TIA |
The bolt is M6 x 12mm according to Microcat 2012. The same size bolt is used to hold brackets on the branch of the pipe that heads towards the secondary turbo. |
Thanks Graham. I thought it might have been an M5 as the head is 8mm and the shaft is 5.5mm wide. |
