![]() | Home > Technical (L322) > 4.4 TDV8 Throttle Body |
damonky Member Since: 24 Apr 2018 Location: Devon Posts: 19 ![]() ![]() ![]() |
Greames did you manage to find a suitable o-ring, and did it work?
For anyone looking, The part number is LR022663. |
£150 - just add more PTFE!! 2012 TDV8 Vogue (L322) |
I think I will be |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2566 ![]() ![]() ![]() |
I'll be trying BS620 (ID 79.77mm, section 5.33mm), having recently measured the spigot at 81mm and the housing 90mm.
JoshVogue94 Member Since: 18 Aug 2022 Location: RCT Posts: 56 ![]() ![]() ![]() |
I went around my throttle body with a few layers of electrical tape until I got a nice tight seal instead of the PTFE tape to be sure it wasn't going anywhere |
My local bearing supplier has no information on BS620 so next week when I go to town I'll see if I can get BS338 and BS339, the adjacent original BS sizes in 3/16" section either side of BS620 to try. I didn't take my charts so didn't know the numbers of the adjacent sizes.
I managed to get a 5 pack of bs620 from https://www.simplybearings.co.uk/shop/ after trying ptfe tape.
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 693 ![]() ![]() |
Hi Damonky,
I'll have to have another look at mine as I didn't spot a clip-in section although I wasn't expecting one either. |
I've found seals similar to the original seal but I need to re-measure mine and take a picture to see if any of the seals could be used.
hi @MarianaWestminster,
Checked mine today and there were signs of a leak. When I took the elbow off the lower part of the throttle body tube was flattened so looks like someone had been clumsy last time it was off (it wasn't me). Used 2 O rings, some thick PTFE and some silicone grease to ease it on and it needed a good hard push to get the wire retainer to engage but it's now very tight and secure. 2012 TDV8 Vogue (L322) |
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 194 ![]() ![]() ![]() |
I use FUM-tape. Make throttle body diameter littlebit bigger with that and now elbow is not loose anymore with old seal. No signs of leak half year already.
