Home > Technical (L322) > 4.4 TDV8 Throttle Body
Page 2 of 5 <12345>
DrRob
Gazcw wrote:
MAF
Thanks šŸ™
Does the car need ā€œtellingā€ it has a new one fitted? No fault codes before fitting or after.
Test drive tomorrow am.
I changed it as my old one was getting a little sooty underneath on outside. Some have tried ptfe tape but I thought Censored it letā€™s order a new one from Duckworths and see how it compares on fit.
Iā€™m all about preventative maintenance Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #558392 20th Jun 2020 7:22pm
GraemeS
Australia
DrRob wrote:
Is that the air intake temperature sensor?
Yes. The MAF sensor is at the air-box.
Post #558416 20th Jun 2020 9:36pm
DrRob
Thanks. I checked with an LR ex mechanic and he confirms itā€™s a sensor to monitor boost temperature. If it goes up too high a value then boost is backed off Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #558431 21st Jun 2020 8:26am
They arenā€™t the tightest of fit out of the box.
I did the one on mine as it was a bit sooty, canā€™t say it made a difference, and the new one was only slightly better seal wise. A couple of wraps of PTFE sounds like a decent idea so long as itā€™s secure and doesnā€™t get into the intake.....
I didnā€™t tell mine it had a new one. Donā€™t think there is a method for this in any case.šŸ‘šŸ» There is nothing that can't be fixed with a hammeršŸ˜œšŸ˜œ
Post #558443 21st Jun 2020 10:02am
DrRob
Sorry, he also said no IID coding needed etc.
Agreed, didnā€™t feel massively tighter but all done Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #558479 21st Jun 2020 4:04pm
Gazcw
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
Has the airflow temp sensor got any maker or spec markings on it?
If we could figure out its resistances or however it works, it may be possible to source an alternative and use something like this to dispose of the poor fitting, overly priced lump of plastic.
https://www.viperperformance.co.uk/silicon...-hose.html
[img]
[/img]
Thoughts? 2011 4.4tdv8 Vogue
Baltic Blue
Post #558888 24th Jun 2020 7:53pm
DrRob
Iā€™ll take a look at the old one and let you know Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #558910 24th Jun 2020 8:47pm
Gazcw
Ok. The alternative is to cut the spring section off, leave the sensor in and use a piece of silicon pipe between the two.
I may look at that tomorrow. 2011 4.4tdv8 Vogue
Baltic Blue
Post #558911 24th Jun 2020 8:58pm
DrRob
Good idea too Thumbs Up
I assume you have an old one to fettle? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #558925 24th Jun 2020 9:40pm
Gazcw
No I haven't but I am in need of a new one I think as my soot levels are climbing too quickly.
Went to London yesterday and had 5 regens. I had ptfe tape on and when I removed today it was clearly oily and sooty.
So it is a few quid for a bit of silicone if possible to do or 120+ for another ill fitting connector. 2011 4.4tdv8 Vogue
Baltic Blue
Post #558929 24th Jun 2020 10:01pm
DrRob
I'd be tempted to buy a new one off Duckworths (quick delivery by Robin I might add) and then you have your old one to play around with an alternative solution. I think the easiest way will be to cut off the end with the seal/clip thus leaving the plastic pipe with sensor and "side pipe" intact and then find a wide bore silicone hose to bridge to the throttle body. There is a fair length of throttle body "metal" for it to cover too....
Also, with a new one on you can directly compare soot levels on the same trip to London if you do it again soon Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #558940 25th Jun 2020 7:46am
GGDR
5 regens is a lot
. Cheers, Greg
Post #558951 25th Jun 2020 9:24am
JoolsB
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
kevinp wrote:
DrRob wrote:
How is the clip removed to remove the pipe?
It's a lot easier to get off if you remove the rubber hose completely from the intercooler first. Less chance of breaking that delicate water connection that goes over it. Then with a screwdriver gently pry the clip out of its locating slots. Just make sure you bend it to a complete circle before putting it back on with the split at the bottom.
Does anyone know the part number for the delicate water connection - Iā€™ve just broken mine and need to get a replacement, canā€™t see it on the advanced factors site
Cheers
Post #618565 3rd Jan 2022 4:35pm
rjff
Replied to your other post Thumbs Up Cheers
Richard
Gap IIDBT
Post #618578 3rd Jan 2022 5:14pm
JMC
LR029140 Thumbs Up The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #618579 3rd Jan 2022 5:16pm
Page 2 of 5 <12345>
