Home > Technical (L322) > 4.4 TDV8 Throttle Body
Page 4 of 5 <12345>
GraemeS
Australia
I'll be measuring mine for an o-ring when I get a chance, with my preference leaving the green seal in place if there's room. The plastic housing doesn't move much but that could be due to the retaining clip rather than lack of gap for an o-ring.
Post #635956 2nd Jul 2022 11:12pm
damonky
United Kingdom 2011 Range Rover Vogue 4.4 V8 Orkney Grey
Greames did you manage to find a suitable o-ring, and did it work?
I've tried ( perhaps not enough) PTFE tap but still getting the leak, does anyone have the part number for the elbow or links to buy it?
Thanks, -----------------------------------
2011 4.4 TDV8 Vogue
Post #645487 13th Oct 2022 11:56am
damonky
For anyone looking, The part number is LR022663. Very Happy -----------------------------------
2011 4.4 TDV8 Vogue
Post #645495 13th Oct 2022 12:32pm
JayGee
£150 - just add more PTFE!! 2012 TDV8 Vogue (L322)
Post #645496 13th Oct 2022 12:39pm
damonky
I think I will be Rolling with laughter -----------------------------------
2011 4.4 TDV8 Vogue
Post #645508 13th Oct 2022 3:22pm
GraemeS
Australia
I'll be trying BS620 (ID 79.77mm, section 5.33mm), having recently measured the spigot at 81mm and the housing 90mm.
If its a good fit then I'll order a couple of Viton ones.
The o-ring would replace the original seal.
Post #645531 13th Oct 2022 9:09pm
JoshVogue94
Wales 2011 Range Rover Vogue 4.4 V8 Santorini Black
I went around my throttle body with a few layers of electrical tape until I got a nice tight seal instead of the PTFE tape to be sure it wasn't going anywhere
Post #645538 13th Oct 2022 11:15pm
GraemeS
Australia
My local bearing supplier has no information on BS620 so next week when I go to town I'll see if I can get BS338 and BS339, the adjacent original BS sizes in 3/16" section either side of BS620 to try. I didn't take my charts so didn't know the numbers of the adjacent sizes.
Update: BS338 is too thick and nitrile used in standard o-rings doesn't compress easily enough. Possibly a metric 81mm x 4.5mm would fit especially if available in silicone.
Post #645842 18th Oct 2022 2:55am
damonky
I managed to get a 5 pack of bs620 from https://www.simplybearings.co.uk/shop/ after trying ptfe tape.
To put it on i took out the clip in ring that holds the old seal inplace. It was tight so mounted it on the body, and not in situe as i struggled to get it mounted that way.
With a bit of wiggling its now in place and has fixed my turbo leak. I’ve done a couple thousand miles since and the car is transformed. Better fuel economy (+4/5mpg), pickup and gear changes. -----------------------------------
2011 4.4 TDV8 Vogue
Post #648225 16th Nov 2022 11:22am
MarianaWestminster
Hi Damonky,
Good job finding an o ring.
Could you clarify what you mean by mounting it on the body as opposed to in situe?
Also did you order the Viton variant of the o rings linked?
Kind regards
Post #648850 22nd Nov 2022 11:18am
GraemeS
Australia
I'll have to have another look at mine as I didn't spot a clip-in section although I wasn't expecting one either.
Post #648852 22nd Nov 2022 11:44am
GraemeS
Australia
I've found seals similar to the original seal but I need to re-measure mine and take a picture to see if any of the seals could be used.
Post #648854 22nd Nov 2022 12:24pm
damonky
hi @MarianaWestminster,
I ran the o-ring for a while but eventually it seems to have blown through, need the wiper x. seal - in the end I just bought the replacement part as I went to several outlets and none had it. -----------------------------------
2011 4.4 TDV8 Vogue
Post #658676 6th Mar 2023 7:50pm
JayGee
Checked mine today and there were signs of a leak. When I took the elbow off the lower part of the throttle body tube was flattened so looks like someone had been clumsy last time it was off (it wasn't me). Used 2 O rings, some thick PTFE and some silicone grease to ease it on and it needed a good hard push to get the wire retainer to engage but it's now very tight and secure. 2012 TDV8 Vogue (L322)
Post #663611 7th May 2023 5:05pm
jaguar3
Estonia 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
I use FUM-tape. Make throttle body diameter littlebit bigger with that and now elbow is not loose anymore with old seal. No signs of leak half year already.
Its very soft and gentle tape and can make very good result with that.
Post #663759 10th May 2023 3:35pm
Page 4 of 5 <12345>
