![]() | Home > Technical (L322) > 4.4 TDV8 Throttle Body |
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 296 ![]() ![]() ![]() |
Thanks both |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Easy enough to remove the intake pipe and not break the brittle plastic coolant pipe. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
PyroJames Member Since: 28 Aug 2020 Location: cambridge Posts: 6 ![]() ![]() ![]() |
For all those that replaced the elbow did it fix the RP problem? Just wondering before I go and order a new LR022663! |
Mike Edwards Member Since: 13 Feb 2021 Location: Northampton Posts: 226 ![]() ![]() ![]() |
Looks like the Restricted Performance message has happened on my car before. Not sure a cable tie counts as a long term fix but I’ve done 10K miles since buying the car and this has clearly been in place for a lot longer than that.
Given that the throttle elbow is rigid plastic it's hard to see how a zip tie is doing much to hold it on. It's missing the lock ring which fits in the slots BTW. 2012 TDV8 Vogue (L322) |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1296 ![]() ![]() ![]() |
The locking ring is under that zip tie. |
Sorry I was looking at the empty slots |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
Funnily enough I had intake gunk appear beside mine. Cleaned it up a while ago and I've got more again and the DPF full message pop up yesterday (amber one saying see handbook) after I gave it an inspection. It's around the metal clip area. Can't imagine my DPF is actually full as I did 200 motorway miles last Friday and haven't been far since so, a regen would have happened.
Gary, it has a double lipped green seal inside that leaks and nobody has managed to find a suitable seal to replace it with. I had to have a complete hose which has solved my leak. |
I took mine off tonight and took a photo. Prompted the periodic clean and clean of the MAP sensor anyway (which was all gunked up). This must be what fails - the green seal partially collapses (see yellow areas).
Wow, the green seal on mine sits all the way in the slot with very little protruding.
Yuk!. Checked mine today and it's loose' but not leaking so the seal must be working. No idea why this connector is not rubber with a jubilee clip. 2012 TDV8 Vogue (L322) |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2644 ![]() ![]() |
Is there any possibility of fitting an o-ring on the housing? I don't know if there's room for one as I haven't had mine off for quite some time. |
To be honest, I don't see how PTFE tape, rubber tape, self amalgamating tape or an o-ring wouldn't work as a seal instead. Take the double lip put and measure the diameter and thickness for an o-ring? All these things cost less than £1 so, worth a try before forking out nearly £200 on a new hose.
