Home > Technical (L322) > Fixing damage
Page 1 of 5 12345>
longd
Fixing damage
Hey guys not sure if anyone is interested, but my car got a smack in work , I’m in the process of sorting it out and I’ve been very fortunate to be given help from members on other problems and if it helps someone I’ll do a write up …
Long story cut short I’ve been told the damage is unrepairable and the panel needs to be replaced.
Quoted from body shops were all silly money.
So I bought myself a few new tools and decided to have a bash myself
Post #643147 16th Sep 2022 8:34pm
longd
So basically the damage is qtr panel, rear light and bumper .
Biggest problem in the qtr panel , it’s folded in, creased and ripped . Everything else is bolt on.
So first thing needed is to find a bumper and light fitting, no work can be undertaken on the qtr panel till these are acquired, as these are the reference points for reshaping the qtr panel . .
Light was 140 quod off eBay perfect match .
Bought a used bumper and the one I got was terrible the lad I bought it off should be ashamed of himself selling something so bad I hope his airbags leak Smile Bought another used one from forum member on here and while it looked good all the tabs were broken .
No big deal first job repair the tabs
Post #643150 16th Sep 2022 8:47pm
dingg1
Good to see you having a bash (pun) do you have previous bodywork experience (panel beater)?
Had something similar sorted out here where old school panel beating still exists, they did a brilliant job for not too much money tbh.
Going to be interesting to see your progress
Good luck Thumbs Up
Post #643155 16th Sep 2022 9:06pm
longd
No background as a panel beater or painter.
But I have a lifetime of fixing stuff I break ?
On topic… because every bumper I’ve see has broken tabs I really didn’t want to put the bumper on line everything up then take it off to paint so I decided I would paint the bumper prior to putting on , so I filled , sealed, primed and painted the bumper 2 coats of base 3 of clear - the results I got were phenomenal. There is more orange peal on the factory finish than what I produced - I sprayed in my shed I plastic sheeted everything in the shed
Gun used was devilbliss flg5 1.3 cap.
Sprayed base wide open fan and wide open fluid.
Base was sprayed at a little under 2bar.
clear coat sprayed at bang on two bar, super close & super wet, but kept gun moving.
Post #643159 16th Sep 2022 9:30pm
longd
So I roughly beat the panel out a bit
Post #643163 16th Sep 2022 10:04pm
longd
So stripped back all the paint with fiber paint removal wheel on a grinder ,
I then used hammer and dolly’s to reshape the panel - this is a slow process but super easy to do .
Post #643165 16th Sep 2022 10:09pm
longd
After all the dolly work the panel was looking great but was suffering from the phenomenon known as “oil canning“
Common problem from over worked metal.
As I said I’m not a professional and just figured it out as I went . I had overstretched the panel with my hammer and dolly work.
So back to the old skool shrinking the metal.
Hit the panel with heat then use a wet towel to cool the area quickly … well let me tell you this works a teat !! Panel now taught again after a couple of
attempts
Post #643167 16th Sep 2022 10:15pm
longd
Lashed on p38 filler , all blocked down with 60g sandpaper on a 12” block
Post #643168 16th Sep 2022 10:19pm
longd
Not too bad , considering ever body shop I spoke to said it couldn’t be done , well it can’t be done .
Post #643170 16th Sep 2022 10:22pm
mrtidy
United Kingdom 2009 Range Rover Vogue SE TDV8 Zermatt Silver
Bow down Bow down well done that man. 2009 Vogue SE Zermatt silver
Post #643203 17th Sep 2022 2:14pm
longd
So just doing final shaping around the wheel, this profile needs to be spot on I did the flat part first as this set up everything else .
Mark out where the profile is and then sand to the line .
Getting your style lines is super important as the entire shape of the car is altered if you mess this bit up.
I had a little bit of corrosion on back door so I’ll paint and blend on that door.
Post #643246 18th Sep 2022 9:17am
longd
Well now the weather has decided to change and now it’s raining . Was planning on getting paint done today but that’s now not happening .
To recap on body filler and sand paper I used
Fibreglass on inside corner that the metal was torn in,( I was going to weld it but decided I didn’t want to risk distortion of the panel )
P38 body filler shaped with 60 grit
Blocked down with 80grit
Then blocked with 120 grit
Dolphin glaze over that
Misted a bit of whatever rattle can I had on the shelf as a guide coat
Blocked down with 120
Then blocked with 240
I will put 2-3 heavy coats of high build primer over this.
Post #643250 18th Sep 2022 10:22am
Top job, looking good... Thumbs Up Pete
Post #643252 18th Sep 2022 10:29am
longd
Cheers dude
Post #643255 18th Sep 2022 10:36am
Very impressive work indeed there dude. Very Happy
Post #643280 18th Sep 2022 3:08pm
Page 1 of 5 12345>
