Home > Technical (L322) > Help me out with the suspension on my 'famous' 4.4TDV8 L322! |
LandyManSam Member Since: 10 Jul 2019 Location: Wild West Ireland Posts: 51 |
Finally got around to fitting the new Aerosus front struts over the weekend. Even with me filming it for the YouTube video, it was a quick and easy change over. Especially when you've got a dugga-dugga gun for the big lower strut bolts.
19th Jul 2022 9:31am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7841 |
Yeah, had new rear Bilstein shocks for MOT, and car was exactly the same ride wise.
21st Jul 2022 7:48am |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 828 |
has anyone completely replaced all the bushes with something better than OEM - like Polybush ??
13th Sep 2022 12:03am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
If you want to create a crashy uncomfortable ride quality then fitting pollybushes is the way to do it . Having said that if you costed up a OE set of bushes it would likley be the more expensive option and they are often easier to fit as you don't have to press fit metal sleeved joints. 2012 TDV8 Vogue (L322) |
13th Sep 2022 8:10am |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3137 |
DO NOT USE POLYBUSHES!
13th Sep 2022 10:30am |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 688 |
I'd tend to agree with polybushes adversely affecting the ride quality.
13th Sep 2022 5:02pm |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 |
I was thinking about this the other day…
13th Sep 2022 7:26pm |
I fitted the wire repair kit, to one of mine… that had a new connector on… still the same.
13th Sep 2022 7:52pm |
could the Meyle brand be an option for a full set of bushes, am sure all mine propably need replacing after 11 years and a lot of miles - but if I do go OE, who is best to buy a full set from - any ideas welcome on this ?
14th Sep 2022 12:01am |
I’d stick with OE and just replace obviously worn ones. Some are difficult jobs and may not need replacing. 2012 TDV8 Vogue (L322) |
14th Sep 2022 6:59am |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 541 |
This has to be a damper problem. I just don't see bushes affecting the actual ride, road noise and harshness yes, but not actual ride. Are you sure the adaptive suspension is working and not set permanently to 'hard' as in an ECU fault? Drives:
14th Sep 2022 7:31am |
It’s definitely a damper problem. Or signal to damper problem.
14th Sep 2022 8:09am |
I think its a damper control problem as my front LH damper is 4 years old. Front right and the rears are new fitted this year.
14th Sep 2022 5:46pm |
Also, a bit on the back of the connector theory earlier…. The wires… they get brittle and eventually break, mainly near the top of the front struts where it swivels… but what if it’s brittle and iffy somewhere else along the length to the ECU?
14th Sep 2022 6:00pm |
