Home > Technical (L322) > Help me out with the suspension on my 'famous' 4.4TDV8 L322!
Page 15 of 30 <123 ... 141516 ... 282930>
Phoenix
Can I just jump in on this with as bit about PWM signals - it seems to me that if the duty cycle is high, this will cause stiffened suspension, now no amount of voltage measuring will give you the duty cycle. 'If' the duty cycle is correct, then the actuator must be slow in releasing or the viscosity / contamination of the damping fluid is too high.
I don't have adaptive damping so I'm unable to help with actual signals, at some point though, the resolution to this is going to need the PWM signal 'scoping for signal quality and plausibility and the dampers themselves tested for reaction times.
Post #642958 14th Sep 2022 7:16pm
mjdronfield
Yeah, I think either front dampers are jiggered, and can’t respond to signal/solenoid stuck, no oil in… or they are fine and the signal is wrong, due to sensor etc. That’s pretty much where the thread started. It’s finding out which, given it’s gonna cost upwards of £1000 to replace front shocks, and some have done that, with no improvement. I know earlier in the thread someone used a diagnostic tool to look at the ECU signals, but guessing we would each need to do similar to prove one way or the other… and I don’t think you can easily rig up something to send “12v” to the shock and see if it’s soft…
Gonna be the garage I suspect….. and hope they diagnose it correctly….. we can’t be the only ones who are having the issue… maybe it’s age and wear on the shocks….?
Gonna be some unhappy L405 owners soon, if that’s the case….
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #642963 14th Sep 2022 8:05pm
Phoenix
I think you're not too far from me, I'd be happy to 'scope the sensor & output signals, can't do much about the damper internals though!
it won't cure anything but would at least give you a reference point and an idea if it's an issue with the dampers or the control side.
Post #642964 14th Sep 2022 8:14pm
If you do sort a meet then let me know and I'll pop over with mine that has working adaptive damping to set a baseline... Thumbs Up Pete
Post #642967 14th Sep 2022 8:30pm
Phoenix
That'd be a good plan!
Post #642970 14th Sep 2022 8:36pm
mjdronfield
Brilliant gents…. That’s a lovely offer from you both. It’s really spoiling the car for me now. If it needs new shocks, it can have them, but I don’t want to do it if it’s not the issue.
I still have my old rears here too.
I’m in Chesterfield.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #642971 14th Sep 2022 8:41pm
Mark, have a chat to Iain and let me know, I can make most times from Saturday afternoon for most of the next week... Thumbs Up Pete
Post #642973 14th Sep 2022 8:51pm
Phoenix
This Saturday p.m. would work for me, can't leave until after 1330 though - maybe move to PM to save cluttering up the thread?
Post #642974 14th Sep 2022 8:57pm
mjdronfield
Nice one. Saturday pm works for me.
Will move to PM
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #642979 14th Sep 2022 9:21pm
MarianaWestminster
Really interested to hear your findings chaps!
Phoenix scoping out the signals on a working and non working l322 could finally give us direction as to where the problem lies...
If I wasn't tied up this weekend I would absolutely join you all.
Good luck 👍
Post #642993 14th Sep 2022 11:53pm
GraemeS
Australia
Increasing duty cycle increases the bypass valve open percentage which softens the suspension. 100% duty cycle, ie analogue 12V, fully opens the bypass valve to allow maximum flow through the bypass valve rather than forcing the oil through the main valves.
An analogue voltmeter will show an increasing voltage as PWM duty cycle increases whereas an oscilloscope will show that the voltage is 12V switching on and off at the programmed frequency.
Post #642994 15th Sep 2022 12:15am
Phoenix
Cheers for that, I was (obviously) guessing which way the bypass would operate as I'm a bit late to this particular party!
Post #642999 15th Sep 2022 7:21am
GraemeS
Australia
The default bypass valve position is closed.
Post #643004 15th Sep 2022 8:57am
pcourtney
front bushes - Christian took some photos of his 2011
https://www.fullfatrr.com/forum/topic61540.html
Sixth post down, the bushes are gone - big time !
Post #643081 15th Sep 2022 10:16pm
pcourtney
rvbush wrote:
Are you sure the adaptive suspension is working and not set permanently to 'hard' as in an ECU fault?
I don't have any messages on the dash, no Suspension warnings, but would like to figure out how to determine if the car has gone to Hard setting ( as in ECU fault ) , any pointers for me to determine this would be great - thank you
Post #643117 16th Sep 2022 1:40pm
